Home > My Defender > Neglected for too long
Stiff1
So having not done anything with the 110 in a while I got a sudden bust of motivation, picture heavy but I don't post often Laughing
1. Having put the dash back in several weeks ago (been out for 1 1/2 years after replacing wiper spindles... took the opportunity to action a few leak points) fitted a new head unit as old double din was no longer software supported. Wireless Android auto is nice to have
2. Refitted drivers door card, silent coat and 5mm CSF to the door skin and to the inside of the door card. Overkill maybe but sounds sooooo dead now.
3. Gave it good clean in and out
Next
Sidesteps looking ropey but solid, may rub them down and paint
Rear cross member faded again...may go Gloss this time
Frames for rear most seats fairly scratched up(it does get used as a work horse) will look at how hard to get them out to paint
Have a set of Far Corners rear seat brackets to fit (supposed to recline the seats a little for kids comfort)
Have "mis-placed" 4 of the large dash screws, the ones that secure the binnacle top, centre console and "glove box" lid, Does anyone have a link to these or some going spare?
Post #1042532 11th Aug 2024 10:30pm
Procta
i have a few jobs that i was hoping to start on mine, but a 1900 quid bill has put the stop to that, sadly, I am wanting to do a door card change on mine,
What seats are those? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1042533 11th Aug 2024 11:32pm
Stiff1
Seats are from an Evoque, very comfy, look good, electrics a nice touch but they are very high so not for everyone.
Still need to track down 4 of these screws...
Also popped the new fridge in the back...
Post #1042588 12th Aug 2024 3:20pm
โ€œStill need to track down 4 of these screws...โ€
Any help?:
https://www.lrworkshop.com/diagrams/land-r...acia_45040 KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1042589 12th Aug 2024 3:38pm
Stiff1
That's great, thanks. ยฃ4 a screw??? there's a joke in there somewhere Laughing Laughing Laughing
Post #1042703 14th Aug 2024 12:18am
This is LR you are talking about, you pay for the packet, packaging and logo not the produce / product.
Rolling with laughter KEEP CALM AND Drill ON
Post #1042747 14th Aug 2024 12:00pm
L110CDL
What a cracking track playing in pic 10, from the top down Very Happy Clayton.
Keeper.
Post #1042966 16th Aug 2024 7:54pm
Stiff1
Isn't it just... actually had set it as the alarm on my phone to remind me to to give an old safe i am restoring a second coat .... Laughing Laughing Laughing
Post #1043141 18th Aug 2024 10:16pm
L110CDL
Laughing Thumbs Up Clayton.
Keeper.
Post #1043242 19th Aug 2024 8:00pm
HardCharger
The Front seats look nice, but how do you gain access to the batteries, relays, and fuses in the seat box? No Better Friend, No Worse Enemy
Post #1043725 24th Aug 2024 3:27am
Stiff1
Hi,
Its just 4 bolts, takes 2min. Not as convenient as a pull out base but in reality I have "HAD" to get the under seat area twice in about 8 years.
A set of Anderson connectors would solve both those instances just never bothered.
Post #1044063 27th Aug 2024 10:54pm
Stiff1
Hi,
Post #1044064 27th Aug 2024 10:54pm
The dust caps you can get for Anderson connectors are good, they might not be quite IP68 waterproofing, but enough to be very resilient to general dust and wet.
I have a couple of them in a 50/50 exposed area to the elements and they have been trouble free since installation, they are great to disconnect from for say front mounted lights as they can carry very good current but also easy to disconnect.
Even the pins are tinned inside so have very good longevity possibilities and less voltage drop for higher current applications.
So much better than say pre insulated spade connectors taped up, and Superseals are good but very limited to their current capacity, even uprated ones still are relatively low. Very Happy KEEP CALM AND Drill ON
Post #1044079 28th Aug 2024 8:27am
Stiff1 - Have you considered a Naka DAB Aerial? I think that would look nice on yours. Thumbs Up KEEP CALM AND Drill ON
Post #1044080 28th Aug 2024 8:28am
custom90 wrote:
... Superseals are good but very limited to their current capacity, even updated ones still are relatively low.
AMP Superseal connectors are rated at 14A continuous per contact, which isn't particularly low. You would be ill-advised to plug/unplug them under load (especially with a DC load) but there are relatively few electrical items on most classic Defenders which use more than 168W.
Post #1044082 28th Aug 2024 8:52am
