Home > My Defender > Neglected for too long |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20443 |
They are excellent for some things thatโs for sure, and easy to disconnect.
When I used the Anderson connectors I used the boots with them as well and 6mm2 cable I believe so there was a tight fit on the cable exits, on the butt joint between the boots I used adhesive electrical tape around that in a neat tight wrap with a tear off tab if needed for disconnection which makes it easier. And I put on some of the captive Anderson dust caps, so they are there if needed if disconnected. This is for the 50A red ones, there are much higher rated ones with pull handles etc as well, Iโm unsure if there are boots for them though, I expect there is from the same manufacturer. Some technical details about them all: See Here. Most people on here already know quite a bit about them anyway. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Aug 2024 12:03pm |
