![]() | Home > Maintenance & Modifications > RDX Flasher Relay Issue |
_Stingrey_ Member Since: 29 Jul 2015 Location: Wirral Merseyside Posts: 15 ![]() ![]() ![]() |
Apologies if this has been mentioned before. I have had RDX LED lights fitted for about 5yrs with the accompanying RDX flasher relay unit. Having had an electrical fault on the defender (Brake/Reversing light fuse blowing when engaging reverse), I put the defender into the garage to be repaired. Having collected the vehicle this afternoon I have since noticed that ALL the indicators flash when I indicate LEFT. When I Indicate RIGHT only the RIGHT indicators flash. I have played around with the relay to see if that resolves the issue but it doesn't.
Do any of you more electrically minded enthusiasts/mechanics know what is causing the issue??? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
What was the repair may we ask? As that can assist in possibly working out what has happened.
Poor ground on transmission is possible, or relay, but, the former I think is more likely. Was there an MOT? WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ Last edited by custom90 on 16th Jul 2024 1:34pm. Edited 1 time in total |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
I think the poor ground on the transmission is the likely culprit. I had this once after an LT230 swap. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
