Home > Maintenance & Modifications > RDX Flasher Relay Issue
_Stingrey_
England 1994 Defender 110 300 Tdi CSW Alaska White
Apologies if this has been mentioned before. I have had RDX LED lights fitted for about 5yrs with the accompanying RDX flasher relay unit. Having had an electrical fault on the defender (Brake/Reversing light fuse blowing when engaging reverse), I put the defender into the garage to be repaired. Having collected the vehicle this afternoon I have since noticed that ALL the indicators flash when I indicate LEFT. When I Indicate RIGHT only the RIGHT indicators flash. I have played around with the relay to see if that resolves the issue but it doesn't.
Do any of you more electrically minded enthusiasts/mechanics know what is causing the issue???
Post #1040030 15th Jul 2024 7:17pm
htb2
Wales
Have you contacted the garage, what have they fixed/changed never had anything to do with led lights.
Have they changed out any light units? or messed up an earth.
Only time i came near led's was looking at a vw pickup that had led rear lights fitted, caused the engine warning light to come on.
Post #1040032 15th Jul 2024 7:41pm
What was the repair may we ask? As that can assist in possibly working out what has happened.
Poor ground on transmission is possible, or relay, but, the former I think is more likely.
Was there an MOT? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #1040037 15th Jul 2024 8:28pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I think the poor ground on the transmission is the likely culprit. I had this once after an LT230 swap. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1040068 16th Jul 2024 6:33am
