Home > Puma (Tdci) > Suspension knock
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Suspension knock
SO. Was driving yesterday and started to hear a knocking sound on the rear right when going over bumps. Thought it was the wheel bearing gone again (that being the most buggy side) but upon inspection it turns out to be connected to the top side of the spring.
I'm not sure if there's a rubber ring or coating that's supposed to be there but something is definitely degrading between the spring and chassis mount point and I cannot find what it is. The only diagram on LRWorkshop is for a two spring setup which doesn't apply in this case. And the part for that is the "helper ring" RRC3352.
I'm stumped.
Any clues on figuring this one out?
 110 SW 2.4
IZUMI BLUE
Post #1025773 23rd Feb 2024 9:59pm
That looks like the remains of a spring isolator, and looks like it’s degraded, or partially.
Probably leaving a small gap between the remains on the parts that’s is left of it and knocking the spring to the chassis spring seat probably only about a 5mm gap where it’s making contact hence the knocking.
Unless the very top part of the coil is broken but doesn’t look to be.
Take the accessible remains of it away, if that doesn’t cure it then the spring will need to come out and have the remains of the isolator took off and a new one refitted or leave it off.
Wrap around ones, you can probably fit in situ, the castellated ones you can’t. WeWillWin🇬🇧🇺🇸
Post #1025777 23rd Feb 2024 10:45pm
TexasRover
Originally I don't think the defender has spring isolators so you should not find it on a parts list, but you can fit RRC/Disco isolators. This should reduce road noise supposedly.
The 110 has larger springs in the back, but you can isolators from a land cruiser that fit.
Post #1025782 24th Feb 2024 7:00am
rustandoil
ANR3060
I got mine from Gwyn Lewis Thumbs Up
Post #1025787 24th Feb 2024 7:56am
To me from that photo that looks like the spring shedding its paint or powder coat and I'd be surprised if that is the source of your knock.
Have you checked the damper bushes, a very common source?
Post #1025788 24th Feb 2024 8:03am
andylee
also worth checking the anti roll bar links, these cause a knock when worn out
Post #1025799 24th Feb 2024 10:54am
landy andy
It looks like the heat shrink type protective sleeve that they put on the end of coil springs is coming off.
Post #1025809 24th Feb 2024 12:08pm
markb110
One that gets overlooked, and has happened to me, the bolts holding the upper shock mount.
The nuts on the inside needed nipping up. Wasn’t obvious when looking at it from the outside.
Other than that get a willing volunteer to rock the truck as you lay underneath. Also , noises travel, so don’t forget to look elsewhere.
Good luck
Post #1025820 24th Feb 2024 1:39pm
Dinnu
+ 1 although its not a heat shrink as it is split along the length. I have purchased spare in the past, but cannot find the part number again. They are used on dual rate springs to prevent metal to metal contact when the coils bottom out.
Edit: it could be ANR3060 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1025826 24th Feb 2024 2:43pm
A frame ball joint and or associated bushes is another knock issue to the rear, took me while to find that one, usually get it coasting lightly on and off power and it’d knock like a trailer tailgate locking forward and back, and the actually ball joint had excess play.
New genuine bushes, and greasable ball joint from gywn lewis and all was fine since, something else to grease as well. Laughing WeWillWin🇬🇧🇺🇸
Post #1025832 24th Feb 2024 4:17pm
TriniDaddy
So turns out it was a combination of things. The stuff coming off the spring was indeed the coating. Put some hose over it and no issues since. Then another noise came when I had my shocks replaced (incorrectly) and one snapped. Then, there was a rust spot on the bracket for the roll bar bush that caved in. Had that mended and just changed the bushes. No noise. Even the brakes stopped squeaking! I have a poly bush kit so replacing them bit by bit. Did the sway bar ends. But you were so right!!! The A frame ball joint is shot. That's the next project.
Which brings me to my question...what's the advantage of the adjustable ball joint? 110 SW 2.4
IZUMI BLUE
Post #1037966 20th Jun 2024 6:57pm
Main reason I went for it is just because it is grease-able, that I think is useful for the A frame ball joint.
If / when the steering ball joints need replacing in future again I’d go for grease-able, but that’s just me.
I had tried Polybushes once, luckily only on the dampers and went back to genuine rubber after bad experiences.
Rubber last quite well, and it’s cheaper to replace rubber than components as well. WeWillWin🇬🇧🇺🇸
Post #1037967 20th Jun 2024 7:22pm
landy andy
I fitted a greaseable adjustable rear A frame ball joint and all was good for a year. During this time it was greased once. Then I got a knock. A frame ball joint play. To adjust it involves removing the ball joint to do this. One month later. Knock knock. Adjusted it again. Few weeks later. Knock knock. Then I fitted a greaseable, non adjustable and I’m far happier with it and so far has stood up to a lot of abuse.
https://gwynlewis4x4.co.uk/product/a-frame...ng-gl1041/
Gwyn’s are already fitted with poly boots, and in the housing. He can also provide the two bolts.
Post #1037973 20th Jun 2024 9:28pm
That’s the one I went for. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1038041 21st Jun 2024 2:35pm
