Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display
Page 3 of 10 <12345678910>
G4R1
Hi @ckamps
The missing part number I believe is LR153013
Please keep us updated on the cable connector/adapter.
Also as per the upper dash trim guys from Vulcan Automotive are explaining in the following video that no replacement is required. Only a minor modification. Starts at 3:40
 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #1010529 8th Oct 2023 4:17pm
ckamps
United States
Thanks for the part number. Makes sense. I was trying too hard to match it visually.
I updated my earlier post with that part number.
Post #1010533 8th Oct 2023 4:34pm
ckamps
United States
Reposting from one of my earlier posts on a different Land Rover forum…
A few more resources that might be useful to people considering either the 11.4” or 13.1” screen retrofits:
11.4” retrofit process overview:
&si=eNuscBIBgXZ5qQ06
Might be a useful reference for the disassembly process.
Comparison of 10”, 11.4”, and 13.1” screens:
&si=-cUurliilz50F7I_
Note the reference to reusing Summer Auto’s proprietary 11.4” bracket in support of the 13.1” screen. This reference aligns with what Summer Auto/Zhous has shared with me via email.
It’s not yet clear to me if using the Gap IID Tool’s access to the 11.4” screen setting would apply to the 13.1” screen. In other words, I wonder if the 11.4” -> 13.1” retrofit doesn’t end up changing the resolution. (I had a similar experience retrofitting a Golf MK7 screens in that retrofitting didn’t provide a corresponding increase in resolution. Still a useful upgrade for me, but not ideal.)
As mentioned in a prior post in this thread, Summer Auto/Zhous is willing to sell a SKU of all the parts minus the larger screen for those of us who might source the screens separately.
Post #1010534 8th Oct 2023 4:47pm
G4R1
@Clark4x4
I have received all the connectors required but I'm getting a bit confused.
Could you please help me with the connector pin locations?
The grey connector has 12 holes 1-12 and the Green one has 4.
Could you please clarify which pins from the Green connector go to which holes in the Grey connector?
My understanding is:
(Green)----->(Grey)
Pin 1 goes to Pin 12
Pin 2 goes to Pin 9
Pin 3 goes to Pin 3
Pin 4 goes to Pin 1
Also would be great if you could help with the existing pins that need to be removed from the existing connector and placed into the Black connector.
I believe there are 4 cables/pins
a) grey/violet
b) violet/green
c) grey/violet
d) black
This is my guess of how it should be connected: Please correct me if this is wrong.
(Green)
Pin 1 connects to Pin with Black wire (d)
Pin 2 connects to Pin with Grey/Violet wire (c)
Pin 3 connects to Pin with Violet/Green (b)
Pin 4 connects to Pin with Grey/Violet wire (a)
Post #1013412 31st Oct 2023 6:51pm
Clark4x4
Spain
Ok,
let me try to help. Green connector is used just to avoid to cut cables... this connector can use current pins, that are not valid for Grey connector.
take a look to this graphic, you could see both connectors for both screen models:
so, for example, if you take connector from small screen,this one:
Pin1, black, need to end connected to pin 12 big screen grey connector:
Green connector, I use pin 4 for black cable, but could use other position.
in my case, i made green connector so:
Pin 1 from old blue/black connector connected to pin 4 of green connector (we could consider this connector as a "brige"), because these pin 4 is connected to pin 12 in grey connector.
1-->4-->12 (old blue connector, green connector, grey connector)
same way pin 12 from blue conector, color grey-violet, I connected to pin1 in green connector, because this is connected to pin 12 in grey connector.
12-->1-->12
and same for can bus cables:
4-->2-->3
10-->3-->9
I sugest to draw it, like I did in last picture.
Or sent a picture of your cable and I try to do it...
And don't hesitate to ask if is not clear...
Post #1013554 1st Nov 2023 5:09pm
G4R1
Thank you @Clark4x4
All clear now. In simple terms, the location of the pins in the "bridge" does not make any difference as long as the existing pins connect to the new screen as below:
@Clark4x4 could you please also clarify if you have made any modifications/trimming to the upper long dash trim in order to accommodate the large screen? 3.0L MHVE D200 S Pangea Green+Black Pack
Post #1013563 1st Nov 2023 5:54pm
Clark4x4
Spain
Well, I didn't modify anything related to dash trim. I know lower trim is different, but once mounted I didn't detect any issue, let me show it:
only in back upper seems not adjusting totally, but is not noticiable and I'm not sure it'll be an issue...
Post #1013646 2nd Nov 2023 1:17pm
mani_jeenu
Australia
Does anyone know if you can simply change the CCF setting to support the 13.1" screen via GAP IID tool and got it working?
Also for those who want the part numbers for both screens:
Post #1018021 11th Dec 2023 1:04am
Clark4x4
Spain
Well, not sure to be honest... I think that yes, must work (in CCF there is only one "Alpine" option if I remember well)... I guess until someone test it we don't know.
Post #1018328 14th Dec 2023 6:46am
mmbanf
Italy
hello and good morning everyone,
I'm looking into finding spare parts to retrofit the 11.4 screen,
I'm not sure if the screen software is all adaptable to defender, mx63-19c279-ae, it can also be found as indicated on jaguar, will it work? or will there be layout problems?
Has anyone had any other experiences?
Thank you
Post #1035983 29th May 2024 9:37am
Clark4x4
Spain
Hi,
I would say yes... I mean, find my module (retrofited by myself):
and is working perfectly, except VIN, wich is from donor vehicle.
By the way, drop me a PM, maybe I jump (or try) to 13.1... I'm thinking in try to upgrade, but not sure...
Regards
Post #1035989 29th May 2024 9:55am
abyss
Australia
Hi Clark 4x4,
That’s a great post and I managed to source the 11.4 screen and all the bits. I followed the wiring diagram and I think it is correct. For some reason the screen is still blank after update the CCF using my Gap G4 tool.
Not sure why is that?
Post #1036845 8th Jun 2024 12:21pm
G4R1
Have you tried to reset the Pivipro? It might take 2-3 resets until it turns on. 3.0L MHVE D200 S Pangea Green+Black Pack
Post #1036846 8th Jun 2024 12:31pm
abyss
Australia
Yes I did about 4-5 screen reset still blank screen.
CCF upload successfully but unable to do the adaptation?
My 11.4 screen is brand new but I’m pretty confident the wiring is correct as per this topic.
Post #1036879 9th Jun 2024 12:47am
mmbanf
Italy
Hello,
then the problem is clear.
first the modification of the ccf file with the Gap G4.
when you install a NEW ecu module on land rover, you have to do some programming, download the car model software and associate the ecu with your vin number....
To do this you need the official Pathfinder or Topix cloud software (for cars after 2023),
so you have two solutions:
you have a compliant dealer who does the work for you (it takes about half an hour).
or you can contact Gary from svs who will program the module for you remotely.
Good luck!
Marco
Post #1036882 9th Jun 2024 6:23am
