Home > Puma (Tdci) > Puma 2.2: Very stiff clutch normal?
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Good evening All,
I've finally acquired my Defender which is a 65 reg and only 12k miles. It's never towed and looking at its condition it's clearly been cherished.
I know the clutch pedal feel on these are not eco box light but are they normally really stiff? I have searched the topic and read a lot about boosters etc but nothing specifically about what should be normal. I found one comment stating that the 2.2 already has a lighter spring and if the clutch is stiff that it is a sign that it's likely very worn. Is this true?
I drove a similar mileage 90 last month and its pedal was feather light but the seller stating it was all stock and it only goes stiff with age and/or when it's really worn.
In short, should I be worried that my clutch is likely needing replacing?
Thank you,
P
Post #1035179 19th May 2024 10:57pm
DAZ110
Mine was squeaky and fairly stiff. I did the following and it certainly helped:
https://www.defender2.net/forum/topic22839...+pedal+box
Also I took the cover off that’s under the bonnet and sprayed some light lubricant in there.
Post #1035192 20th May 2024 9:06am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Spend the £25 and fit the LOF clutch pedal spring. I did this last week after years of accepting it as the norm and the difference is incredible.
https://www.defender2.net/forum/topic66507...tch+spring
Still need to fix my squeak though Rolling Eyes 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1035198 20th May 2024 9:59am
Puma_MOG
Thank you all for the feedback.
I read both links in detail again, after having read them last night. I'll have a look tonight after work.
So it's normal then it to be this stiff? It's a 65 reg with 12,000 miles and not having a tow bar, clearly hasn't towed, hence being worried that something isn't right.
I checked the fluid and while it's not 100% clear, it looks decent enough but perhaps best to get that flushed early.
Post #1035209 20th May 2024 12:27pm
MK
I guess the best would be to compare again with another 2.2.
And yes, the clutch pedal on a Defender is quite stiff. Puma 110" SW
Post #1035212 20th May 2024 12:55pm
It should only be stiff when new for the first few hundred miles.
Lube the pivot on the pedal box and go from there, also check the clutch fluid.
If the master cylinder is over ten years old I’d consider changing it.
Especially if it has black fluid, which is the seals that are breaking down.
I know I left a dealer once with a new clutch it was so heavy I thought it was not working as it should, but then it settled to normal.
I wouldn’t imagine it’s air in the fluid as that’s more compressible.
Edited* If the fluid is looking decent then that’s not so likely.
I’d lube the pedal pivot and go from there, the slave if that leaked would make the pedal more soft I’d have thought.
It might be that a new master is needed, it could be an issue there with the seals WeWillWin🇬🇧🇺🇸
Post #1035217 20th May 2024 1:53pm
Puma_MOG
Thank you custom90
I'll have a go at what you described and will use the info on this forum to fill in any blanks in my limited knowledge Smile
My guess is that perhaps something has seized up what with the low miles and limited daily use it's had in it's past life. Now feeling a bit less worried in assuming I have a new clutch bill to pay for.
Post #1035221 20th May 2024 2:16pm
Puma_MOG
I've opened up the box and all is quite dry in there. I've read some posts about adding a nipple and giving it some grease but it wasn't clear if this applies to the Puma. The side of my box has a larger rubber bit coming out of it. More interesting is that the screws holding the lid show signs that it's been taken off before.
Do I spray/lube anything here?
Post #1035230 20th May 2024 4:03pm
DAZ110
Would a thought a bit of silicone grease sprayed in there wouldn’t hurt.
Post #1035241 20th May 2024 5:07pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
I added the nipple to my Puma, RHS based on your photo.
Likewise I just added grease once the cover was off… belt and braces!
Spring also done.. clutch has changed from being heavier than a photocopier (34k miles), to a dream..
Night and day difference (and squeak free!) Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1035249 20th May 2024 6:06pm
Puma_MOG
Out of curiosity, where is the grease going? There isn't much in there the box, on mine at least, doesn't have a a bottom so I would assume it's going to just drop onto the engine.
Post #1035253 20th May 2024 6:41pm
No, it drops onto your left foot.
Post #1035255 20th May 2024 6:59pm
Puma_MOG
I was wondering what that was! Laughing
Post #1035260 20th May 2024 8:11pm
Oh yes, that is not good. If there is a nipple fitted just one pump works.
But you can lube it from inside with the cover off as Daz mentioned, the pivot can get stiff if dry, there definitely is some lube that can go on there.
Silicone, or k48 or something like that or lithium would be fine, won’t hurt anyway. Thumbs Up
I’d imagine it’s one of those things that gets a little seized if stood for a while, loosens up with movement like us. WeWillWin🇬🇧🇺🇸
Post #1035266 20th May 2024 9:47pm
Puma_MOG
Thank you again custom90
Post #1035268 20th May 2024 10:04pm
