![]() | Home > Puma (Tdci) > Puma 2.2: Very stiff clutch normal? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20754 ![]() ![]() |
That’s an idea, that will make it a bit more wet and speed it up a bit. Grease drying up is a problem too so thats a good idea a bit of light oil as well.
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 185 ![]() ![]() ![]() |
Noted and thank you Ian. I will be honest and say I sprayed a bit of chain oil in the general area. I assume it's best to take the top off and try wiping everything up as best I can before doing as described? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2270 ![]() ![]() |
I would take the lid off the pedal box, it’s only 6 screws, you just need to be careful you don’t drop one.
The lid has a rubber seal so carefully prise the lid off to avoid damaging it. If there is any of your chain oil on the clutch master cylinder pushrod clean it off as you don’t want any oil getting to and contaminating the MC seals. You can then target the upper and lower pivot ends for lubrication. |
Bunker Spreckels Member Since: 28 May 2024 Location: Buckinghamshire Posts: 1 ![]() ![]() |
Hi mate, I bought a 64 plate XS 110 with 50,000 miles a few weeks ago, I was very surprised at how normal the clutch felt, not heavy at all and this is an completely untouched truck. My only issue is the clunky transmission when I get the timing wrong with revs and gear change. I’d prefer it was rock solid but not sure they ever were? I drove a brand new 90 in 2015 and that was clunky too, but tighter feeling in first. |
Thank you for the feedback.
I applied some lubrication as mentioned in the thread and it has loosened up a bit but still by no means light. I am waiting on the nipple to get some grease in the lower area, as again mentioned in the thread. As for your clucky transmission, my previous 90 felt like that for the life of me I can't recall but something was changed, perhaps half shafts. Totally transformed how smooth it felt. Plenty on here to read on that topic. Thank you again P |
