Home > My Defender > Defender 90 puma low milage but was used on a farm. |
Landy addict Member Since: 03 Dec 2022 Location: Argyll Posts: 75 |
time for update everything painted before assembly.
Click image to enlarge inside the tub quite I am happy with my finish Click image to enlarge seat box Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
14th May 2024 6:10pm |
Bulkhead fitted
14th May 2024 6:14pm |
New intercooler & radiator fitted
Click image to enlarge Screen back in its frame Click image to enlarge wings on Click image to enlarge sound deadening in footwell, electric windows & central locking wires fed through. Click image to enlarge |
14th May 2024 7:06pm |
tub sitting on
Click image to enlarge all new seals & stainless fittings Click image to enlarge |
14th May 2024 7:24pm |
Click image to enlarge Click image to enlarge Made new floor plates from 3mm alloy Click image to enlarge Click image to enlarge Side panels on Click image to enlarge Roof Click image to enlarge |
14th May 2024 7:36pm |
some optimal hinges
14th May 2024 7:40pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10674 |
She is certainly looking different now, thank you for the update 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
15th May 2024 8:50pm |
got rear step & LED lights fitted
Click image to enlarge Front end coming together Click image to enlarge sound system upgrade Click image to enlarge central locking & electric windows fitted to doors Click image to enlarge Click image to enlarge Click image to enlarge |
16th May 2024 11:45am |
Rear door window, work / revers LED lights & ORE wheel carrier fitted
Click image to enlarge rear camera & Optimal rear washer also fitted Click image to enlarge |
16th May 2024 12:01pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2881 |
Great work Is that a set of black Sawtooths on BF's I spot for it? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
16th May 2024 3:32pm |
Hi Andy thanks for the comment & yes it is
16th May 2024 4:29pm |
I have an issue cant get it to start, it is turning over but wont run (blead the fuel several times not seeing any bubbles)
When I was first trying all the correct lights on the dash where showing Battery is fully charged Checked every fuse individually all OK checked relay connections cant find any obvious wiring faults changed crank sensor still nothing Connected a code reader to it & it showed a couple of faults (cant even remember what they where now) Now the glow plug light does not light up when ignition is turned on (before it would light up then go out after a bit of time) the temp Gauge now goes to full when ignition turned on Now when the reader is connected it says that the ECU is not communicating. |
16th May 2024 4:55pm |
got it running thanks to you guys see process here https://www.defender2.net/forum/topic92198.html
23rd May 2024 2:01pm |
