Home > My Defender > Defender 90 puma low milage but was used on a farm.
Page 4 of 4 <1234
Shall have to look that up, 3M do some excellent stuff. Mr. Green WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #1019878 2nd Jan 2024 6:35pm
Landy addict
time for update everything painted before assembly.
inside the tub quite I am happy with my finish
seat box
Post #1034760 14th May 2024 6:10pm
Landy addict
Bulkhead fitted
Post #1034761 14th May 2024 6:14pm
Landy addict
New intercooler & radiator fitted
Screen back in its frame
wings on
sound deadening in footwell, electric windows & central locking wires fed through.
Post #1034765 14th May 2024 7:06pm
Landy addict
tub sitting on
all new seals & stainless fittings
Post #1034768 14th May 2024 7:24pm
Landy addict
Made new floor plates from 3mm alloy
Side panels on
Roof
Post #1034771 14th May 2024 7:36pm
Landy addict
some optimal hinges
Post #1034772 14th May 2024 7:40pm
L110CDL
She is certainly looking different now, thank you for the update Very Happy Clayton.
Keeper.
Post #1034870 15th May 2024 8:50pm
Landy addict
got rear step & LED lights fitted
Front end coming together
sound system upgrade
central locking & electric windows fitted to doors
Post #1034906 16th May 2024 11:45am
Landy addict
Rear door window, work / revers LED lights & ORE wheel carrier fitted
rear camera & Optimal rear washer also fitted
Post #1034909 16th May 2024 12:01pm
mcma1
Great work Bow down Is that a set of black Sawtooths on BF's I spot for it? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1034931 16th May 2024 3:32pm
Landy addict
Hi Andy thanks for the comment & yes it is
Post #1034936 16th May 2024 4:29pm
Landy addict
I have an issue cant get it to start, it is turning over but wont run (blead the fuel several times not seeing any bubbles)
When I was first trying all the correct lights on the dash where showing
Battery is fully charged
Checked every fuse individually all OK
checked relay connections
cant find any obvious wiring faults
changed crank sensor
still nothing
Connected a code reader to it & it showed a couple of faults (cant even remember what they where now)
Now the glow plug light does not light up when ignition is turned on (before it would light up then go out after a bit of time)
the temp Gauge now goes to full when ignition turned on
Now when the reader is connected it says that the ECU is not communicating. Big Cry
Post #1034937 16th May 2024 4:55pm
Landy addict
got it running thanks to you guys see process here https://www.defender2.net/forum/topic92198.html
Post #1035480 23rd May 2024 2:01pm
Page 4 of 4 <1234
