Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 89 of 110 <123 ... 888990 ... 108109110>
Mark1107
United States
I have the 11inch alpine and the hvac controls don’t show up on the screen.
"Looneyfitter"]
hthagood wrote:
northeye wrote:
hthagood wrote:
Hairy Dan wrote:
These are the main changes from the G3, most of the MultiCAN numbers were there in the latest G3 firmware but they were all down as not supported, they now have options Thumbs Up
MultiCAN-882 Sidebar Controls
Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-894 Volume Soft Keys
Audio Volume Soft Keys pattern
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
Anyone been able to get the soft volume control to function? All I get is a readout of “0” and no volume control. It will show mute status? Thanks!
I believe that the volume control key will work on only MY24 or above vehicles.
On my friend's MY24 worked, but mine MY23.5 didn't. Crying or Very sad
Disappointing.
. I believe you need the larger screen for it to work[/quote] 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1034247 8th May 2024 10:40pm
Mark1107
United States
There are different multican/ Eucd settings for drl behaviors and settings. Like 10-20 different settings. Multican 458-through Multican 465 like 20 settings. You should experiment and get back to us!
Ratledge wrote:
Just keeping up and for notes, the Parking Assist works up to the point when Start is greyed out.
The GSR2 setting does nothing for my MY23.5 D90S P300.
Has anyone figured out how to force headlights on, like required in Denmark?
Post #1034248 8th May 2024 10:47pm
c4skp
Bobbobbobbob wrote:
Feeling proud of myself that I can potentially make a contribution after all the help I've got from this site.
Driver Assistance is now remembering last setting for me.
Just as a disclaimer I have no real idea what I'm doing with this stuff but it seems to work.
MultiCAN-889 GSR2 EU Market Ft
GSR2 Country
Changed it to Non GSR2 Country.
The regulations which insist on this are called GSR2 and there are a few other related settings.
It works on my 24 uk X. Thanks!
Have enabled this as had to restore multiple times to factory after a lot of failed effort.
Strangely the screen still says will revert to high when restart, but this doesn't, it stays on the selected setting.
Has anyone got the SV logo on startup?
Post #1034319 9th May 2024 5:46pm
tooth_dr
Northern Ireland
I had the parking going as far as ‘start’ it would find spaces etc but start was greyed out. I changed two settings as per post above and it removed the parking steering wheel icon. I since changed it back to my previous setting and now the steering wheel icon is still missing and it doesn’t search for spaces etc. Any ideas?
Post #1034320 9th May 2024 5:51pm
Ratledge
United States 2016 Defender 90 300 Tdi SW Auto Stornoway Grey
I poked around a lot, but nothing looks important. Maybe EUCD-084 I think it was?
Post #1034357 9th May 2024 10:50pm
malibu
Australia
Hi I would like to activate TPMS. I know I need the module in the roof and sensors in each wheel.
Could somebody please check what settings they have? I think it will be Multican 101. There are many settings under 101, so I am not sure which one to select. Thanks
Post #1035447 23rd May 2024 2:34am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Mine is a UK car so this is the setting for EUCD-101
EUCD-101 Tyre Pressure Mode System
TPMS With WBL, DLS & No HSPA & No WT (EU Legislation) Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1035455 23rd May 2024 9:00am
malibu
Australia
Thank you
Post #1035531 24th May 2024 12:52am
malibu
Australia
I am trying to activate Tow Assist 2 on an L462. So the settings are slightly different. So far I have;
579 - Tow Assist 2
793 - ATCM rotary Switch fitted
795 - Selectable with Rotary
All seems to work to the point that the start button is greyed out and the screen says " Raise the Terrain Response Control rotary."
I raise it and nothing happens.
Any suggestions?
Post #1035532 24th May 2024 3:45am
BD1
United States
With walk away locking enabled is there a way to disable the horn from sounding if you walkway with the door open?
Post #1035642 25th May 2024 2:01am
Rovering80
Hello.
New forum member here. I've been using the wealth of info on this thread with a G4 and have successfully activated some really useful features. So thank you in advance.
I do have a question. I have been able to use the TR2 and ATPC features off-road which is brilliant as my car wasn't specced with them.
If this had been activated as part of the original build would Dynamic mode be installed too on a P400e? It doesn't do a huge amount and I'm taking it in for a service soon so would like it to either be installed or not as it should be to avoid any potential warranty questions.
Thanks Current: MY23 P400e HSE Dynamic
Post #1035718 26th May 2024 10:29am
Hairy Dan
As far as I know dynamic mode was only installed on the V8's from the factory, personally I haven't deactivated anything when my car was going in for any work and nothing has been said. But, as it's a 2 minute job to do it if you are worried just deactivate it and then re-activate it when you get your car back. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1035754 26th May 2024 7:01pm
nebc100
Luxembourg
Hello all...
I have a 2017 D5 that has been excellent.
I how also have a d110 P400.
Great vehicle, but I have noticed that on my D5 the rear lights are always on (even when the front side lights are on).
This means that when I am towing a trailer, the side lights on the trailer are always on and that makes it easier to see the trailer in the mirrors.
Is there a setting that will do this in the Defender?
If it is the same as on the older D2 etc, it is related to the region settings on the car, but I don't know what setting it would be on the Defender.
Thanks for any help you can give!!
Nick
Post #1035766 26th May 2024 10:01pm
Rovering80
That’s what I thought. Think I’ll deactivate before the service. As you say easily done.
Thanks for replying and you input on the thread in general. Current: MY23 P400e HSE Dynamic
Post #1035769 26th May 2024 11:03pm
ThunderBob
United States
Parking Assist
I’m having the same issue. I can find spaces, select them but start is greyed out. Using Gap G4, latest firmware (build 90) on a 23.5 P300 North American Build Defender 90.
Were you able to resolve the issue?
Thanks
Post #1036181 31st May 2024 1:26pm
