![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 53 ![]() ![]() |
Has anybody managed to get the Air Quality and Ionizer installed? I have found out how to turn on the screen, the next step is to find the sensors.
fubar Member Since: 16 Sep 2023 Location: Ipswich Posts: 6 ![]() ![]() |
Would love to know what you did to get as far you have on the ion filter -----
Larry Junior: L663 MY23.5 D300 110 Larry Senior: Series 3 Stage 1 V8 109 |
I changed 752 Enhanced Filtration to Enhanced Particulate Filter and sensor fitted and soft button fitted
If you make this change you will see the Air quality screen. If you go into Faults in the GAP tool, it will mention the sensors that are missing. I am not having much luck finding the part numbers for the sensors. I suspect it may require replacing the external temp sensor with one that also measures air pollution, or maybe it is an additional sensor. The next setting I will change is 510 Airionizer. Enjoy |
Thanks mate. I will give that a go on the weekend. I have the L663 so hopefully will be the same as yours. -----
Emp Member Since: 15 May 2024 Location: NRW Posts: 20 ![]() ![]() |
Hello,
I am expecting an MY25 and unfortunately it no longer has Wade Sensing as standard. However, I assume that they are identical mirrors and that I can activate it via my G4 tool. Does anyone know what settings are required? Thanks to everyone for this impressive collection of information in this post. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 255 ![]() ![]() |
Wade sensor settings include the following, whether there is anything else to make it work I am not sure, someone needs to try it on a MY25 car
• EUCD-209 Wade Sensing (0010) Wade Sensing Fitted - Manual Display • MultiCAN-755 Wade Prog Mode Available for selection with timeout • MultiCAN-759 Ultrasonic Sensor Fit Rear Front Flank + Wade • MultiCAN-796 Ter Wade Select In FCPB Rotary used for selection within touch screen MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Wade sensor settings include the following, whether there is anything else to make it work I am not sure, someone needs to try it on a MY25 car or a car without WADE sensing, I would presume the hardware is standard in all defenders although I believe wade sensing closes off some vents to stop water ingress which may not already be fitted to all cars
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
You would need to make sure that the mirrors have the wade sensing sensor fitted, the parts catalogue lists the mirrors as "with water wading equipment" and "less water wading equipment"
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thank you very much. I don't think any MY25s have been delivered yet, but hopefully I'll try it out soon.
Oh damn. I didn't see that. I just saw in the internal order document that it's mirrors without modifications like my MY24 order where it was still standard. If it's not installed, it's probably not worth retrofitting mirrors. |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 442 ![]() ![]() |
Did you also change: EUCD-150 Air Quality Sensor Without Air Quality Sensor to With AQS. ? No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
This is what the mirror underside looks like with the wade sensors, they are really just like a parking sensor.
![]() Click image to enlarge The mirrors for cars with wade sensors are approx £500 each! My car has them fitted as standard but I can't say I've ever used them as they are really quite pointless, you need to know the depth of the water before you drive into it. ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
^^^^^^ agree with your comments.
I have just checked ...... and yes I too have all three on the underside of BOTH mirror housings, as standard. ![]() |
It is inexplicable why they have removed it from the standard in Germany. Now you can only get it with the off-road package and so you are tied to the tires there.
Well, I'll do without it if I have to. It's just a fun feature and we all like to have fun. But not at any price. When I have my MY25 HSE, I'll tell you which mirrors are supplied. Until then, I'm still hoping a little ![]() |
