Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 86 of 108 <123 ... 858687 ... 106107108>
chpsk8
United States
@looneyfitter
No, parking assist won't add that feature to ACC.
Post #1032977 26th Apr 2024 7:07pm
Korsayr
United States
GavinC wrote:
No data available I’m afraid. Ignition on or off. No data.
@GavinC, what MY is your Defender?
Post #1033004 27th Apr 2024 12:16am
c4skp
I am trying to attach my CCF from excel, not sure how to achieve this, short of making a massive long post showing all the options.
Its a 24 X with 4 zone climate and air treatment, along with the tow assist etc.
Have been trying the settings around 889 to make the car remember the driver choice for driver assistance.
Would someone be able to compare this to a vehicle that has had this enabled?
Can email the files to compare
Post #1033015 27th Apr 2024 7:59am
Cometboy
United States 2016 Defender 110 V8 Petrol SVX Station Wagon Auto Havana
Re: US Spec Defender w/Premium Headlamps
dakluck wrote:
Does anyone have a stock CCF file for a US spec Defender with the premium headlights? Preferably closer to the 2020 model year, but I’ll take anything right now to get these headlamps coded correctly!!
hey there. don't know if anyone ever answered you.
i am in NJ and have been fiddling with the G4 and the different headlight units.
In the US market the Premium LED is actually called Matrix Led AFS123/IHB in the CCF using G4.
These are the units that are labeled as KZ3 04S.
if you have the KZ3 05S variant then you have the "Pixel LED AFS123/IHB...
Hope this helps...
be careful of people selling "Matrix LED" for NAS Spec as they are just KZ3 04S "Premium LED" and not the KZ3 05S "Matrix LED" ...
Good Luck Cheers Roger
23.5MY Defender 110 v8 Carpathian w/ mods
Post #1033073 27th Apr 2024 6:17pm
Looneyfitter
GavinC wrote:
nebc100 wrote:
PLEASE let us know what options you activated so we can try and get it working in our vehicles!!
Park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears)
Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error.
I can get it searching and finding spaces but start is greyed out. I have no faults either. My acc and emergency braking went off for a day but now it's fine.
Weirdly my auto star/stop button has gone blank now.
This is my dadc info.
Post #1033190 28th Apr 2024 8:28pm
Looneyfitter
Does anyone know what this setting does? Changes the platform year?
Eucd229
Also multi can 482?
Post #1033192 28th Apr 2024 8:38pm
fst_drvr
I changed MultiCAN-566 to enabled, but my auto start/stop choice still won’t be memorized, anyone has run into the same issue? Thanks
Post #1033336 29th Apr 2024 10:42pm
vincel
United States
Same with me - I've read the change doesn't always work on the pre-2022 model year. I have a 2021, what year is your Defender?
Post #1033338 30th Apr 2024 1:34am
Retroanaconda
It worked on my 2021. It takes a few days to start working like most changes.
Post #1033360 30th Apr 2024 8:06am
vincel
United States
I did the start/stop mod a couple months ago on my 2021 - no joy.
I may return the setting for a couple days and they try again.
Post #1033418 30th Apr 2024 5:19pm
vincel
United States
Post #1033419 30th Apr 2024 5:19pm
Mark1107
United States
Guys,
The self parking is written into the bcm. The gap tool will enable it only on the exceptions, not the rules the rest of us.
Changing model year? I’d ask Patrick or Simon if they would go there? I wouldn’t.
In regards to resetting the DADC the gap tool is weird, if you do changes then let the car sleep idk how long? Overnight? The error messages and cel go away the next day but §the self parking the hvac controls always on display and vehicle perimeter button on steering wheel doesn’t work.
So unless we can look at BCMs not DADC’s then we can compare and see about self parking working.
Cheers. I like the gap tool better than topix cloud and pathfinder because you can’t brick your car. Gap lets you roll back changes.
Also I’ve tried 8 camera settings 10 camera settings and 12 camera settings. Nothing works. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1033466 1st May 2024 1:56am
Mark1107
United States
Start stop last user mode will not disable on the p400. Only p300 us specs.
If you want start stop to be disabled on p400, then you need a lead acid swap for your lithium battery or disconnect the plug black on negative terminal but you will lose heated steering wheel as well.
Only p300 gets last user mode stop start functionality. 2022 Defender Trek Competition 110 collectors edition!
Post #1033467 1st May 2024 2:07am
Defendit..
Netherlands
[ Start stop last user mode will not disable on the p400. Only p300 us specs.]
Not only P300 us specs, I activated mine yesterday with the IIDTool G4 , Europe mainland specs
Multican 566 enabled No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1033482 1st May 2024 8:46am
dakluck
Hope this helps...
Good Luck
I've been going mad on this one. I've tried replacing the headlamp ECUs, every coding you can imagine, and am about to tear into these things. I cannot for the life of me figure out what combination would enable the halo functionality of these new lights.
I even spoke to the GAP team and we did a compare between my vehicle and the donor vehicle. Even with exact CCF settings I still cannot get them to go on. I've heard people mention a headlamp ECU flash, but haven't really found anyone that could actually describe that process and how it could be done.
My replacement pair are KZ3 043 Premiums thankfully, but I'm almost certain at this point that I either need to buy JLR Pathfinder + TOPIx to do a headlamp ECU flash, rip into them and replace LED module, or scrap it entirely and go back to my basic lights. Thread below with more details if anyone is interested!
https://landroverforums.com/forum/2020-def...on-115791/
Post #1033559 1st May 2024 11:37pm
