![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
@looneyfitter
No, parking assist won't add that feature to ACC. |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 24 ![]() ![]() |
I am trying to attach my CCF from excel, not sure how to achieve this, short of making a massive long post showing all the options.
Its a 24 X with 4 zone climate and air treatment, along with the tow assist etc. Have been trying the settings around 889 to make the car remember the driver choice for driver assistance. Would someone be able to compare this to a vehicle that has had this enabled? Can email the files to compare |
Cometboy Member Since: 09 Apr 2024 Location: New York Posts: 6 ![]() ![]() ![]() |
hey there. don't know if anyone ever answered you. i am in NJ and have been fiddling with the G4 and the different headlight units. In the US market the Premium LED is actually called Matrix Led AFS123/IHB in the CCF using G4. These are the units that are labeled as KZ3 04S. if you have the KZ3 05S variant then you have the "Pixel LED AFS123/IHB... Hope this helps... be careful of people selling "Matrix LED" for NAS Spec as they are just KZ3 04S "Premium LED" and not the KZ3 05S "Matrix LED" ... Good Luck Cheers Roger -------------------- 23.5MY Defender 110 v8 Carpathian w/ mods |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 30 ![]() ![]() |
I can get it searching and finding spaces but start is greyed out. I have no faults either. My acc and emergency braking went off for a day but now it's fine. Weirdly my auto star/stop button has gone blank now. This is my dadc info. ![]() Click image to enlarge |
![]() Click image to enlarge Does anyone know what this setting does? Changes the platform year? Eucd229 Also multi can 482? ![]() Click image to enlarge |
fst_drvr Member Since: 08 Apr 2024 Location: Los Angeles, CA Posts: 5 ![]() ![]() |
I changed MultiCAN-566 to enabled, but my auto start/stop choice still won’t be memorized, anyone has run into the same issue? Thanks
vincel Member Since: 19 Feb 2024 Location: NYS Posts: 6 ![]() ![]() |
Same with me - I've read the change doesn't always work on the pre-2022 model year. I have a 2021, what year is your Defender?
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2690 ![]() ![]() |
It worked on my 2021. It takes a few days to start working like most changes.
I did the start/stop mod a couple months ago on my 2021 - no joy.
I may return the setting for a couple days and they try again. |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 74 ![]() ![]() |
Guys,
The self parking is written into the bcm. The gap tool will enable it only on the exceptions, not the rules the rest of us. Changing model year? I’d ask Patrick or Simon if they would go there? I wouldn’t. In regards to resetting the DADC the gap tool is weird, if you do changes then let the car sleep idk how long? Overnight? The error messages and cel go away the next day but §the self parking the hvac controls always on display and vehicle perimeter button on steering wheel doesn’t work. So unless we can look at BCMs not DADC’s then we can compare and see about self parking working. Cheers. I like the gap tool better than topix cloud and pathfinder because you can’t brick your car. Gap lets you roll back changes. Also I’ve tried 8 camera settings 10 camera settings and 12 camera settings. Nothing works. 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
Start stop last user mode will not disable on the p400. Only p300 us specs.
If you want start stop to be disabled on p400, then you need a lead acid swap for your lithium battery or disconnect the plug black on negative terminal but you will lose heated steering wheel as well. Only p300 gets last user mode stop start functionality. 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 ![]() ![]() |
[ Start stop last user mode will not disable on the p400. Only p300 us specs.]
Not only P300 us specs, I activated mine yesterday with the IIDTool G4 , Europe mainland specs Multican 566 enabled No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
dakluck Member Since: 20 Jan 2023 Location: San Diego Posts: 8 ![]() ![]() |
I've been going mad on this one. I've tried replacing the headlamp ECUs, every coding you can imagine, and am about to tear into these things. I cannot for the life of me figure out what combination would enable the halo functionality of these new lights. I even spoke to the GAP team and we did a compare between my vehicle and the donor vehicle. Even with exact CCF settings I still cannot get them to go on. I've heard people mention a headlamp ECU flash, but haven't really found anyone that could actually describe that process and how it could be done. My replacement pair are KZ3 043 Premiums thankfully, but I'm almost certain at this point that I either need to buy JLR Pathfinder + TOPIx to do a headlamp ECU flash, rip into them and replace LED module, or scrap it entirely and go back to my basic lights. Thread below with more details if anyone is interested! https://landroverforums.com/forum/2020-def...on-115791/ |
