Home > Puma (Tdci) > 2 Stroke oil in diesel.
Page 5 of 6 <123456>
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Thumbs Up For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #101774 22nd Nov 2011 10:57pm
Stornaway90
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Zermatt Silver
2 Stroke Added!
Well, I finally rolled over and added Acetvo 2 stroke oil to my Defenders Diesel tank, the results from one tank full and 328 miles are listed below:
1. Engine is a little quieter when cold
2. Engine is considerably quieter when warm with a slightly different tone. (Less like a Diesel especially on the overrun)
3. When starting from hot and cold, it takes a nano second longer to spring into life
4. No smoke when either hot or cold, but there wasn't any anyway (just covered 8000miles)
Other than the listed items above, there does not seem to be any improvement in the vehicles performance, still getting around 330 miles to a tank which I don't think bad at all, if your are after 50 plus miles to a gallon you need one of those noddy cars like a C1.
Will I add more 2 stroke, probably yes, but i am due to change to a new 110 XS shortly and I will be adding this to that vehicle from the minute i get it.
Just in case!!! One Life Live It, There Isn't Anything To Beat It, Even The Boss Agrees.
Defender 110 2012(XS)
Defender 90 2011 (XS) Gone.
Defender 90 2008 (County) Gone.
Triumph Bonneville (SE) Gone.
www.landywatch.co.uk
Post #102313 24th Nov 2011 9:45pm
MartinK
With my td5, I frequently used a bit of old engine oil in it.
In spring, I would change the engine oil (not gear oil) in the Land Rover, the Car, Motorbike & 2 lawnmowers. I had about 4 gallons of used engine oil (worth over �20 in fuel prices).
I bought a filter bag off ebay, and filtered the oil to ensure it was clean (can't remember the filter, but IIRC it was around 5 microns, which was slightly finer than the fuel filter).
Dropping a litre into each tank fill of diesel saved me over a quid every time, made the vehicle run smoother, and saved me the trip to the recycling centre to dump the oil in an environmentally friendly way...
anyone do this on a Puma??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #102524 25th Nov 2011 8:36pm
John110
Would the customs not frown uopn this as It would mask the colour of the diesel? For those who understand, no explanation is needed...
Post #102563 25th Nov 2011 11:40pm
dgardel
Italy
Engine oil isn't good because it produce ash when burned and deposit like glass on the injectors!!!
2SO in made for burn into the combustion process and it helps to mantain W/O ash and dposit the injectors (and reduce fuel system wear). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #102612 26th Nov 2011 12:17pm
Naks
not to mention all the gunk that it removed from the engine, including sulphuric acid! It's like adding urine to your drinking water - crazy! Shocked --
Post #102732 27th Nov 2011 8:42am
dgardel
Italy
Correct you said Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #102743 27th Nov 2011 10:08am
Toplink
Well Gentlemen thank you for all your views and thoughts.
I am going to try 2 so in my puma at a rate of 250ml per tank full,with such a small amount I can't see it doing any harm.I have always changed oil and filter at 6000 mile anyway.
I am also going to put it in my tractor 5.8 litre straight 6 perkins lump.40 gallon tank so 1 litre per fill.
If I post on here about puma engine rebuilds you will know it didn't go well Rolling with laughter Big Cry Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #102800 27th Nov 2011 3:03pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
You'll be fine on it - it works a treat, but remember that the mpg gains take a few at tankfulls to take effect Thumbs Up
Post #102843 27th Nov 2011 8:03pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I have been using 2T for the last 6 months or so, but just for a change, and as the warning light came on i have filled up with BP Ultimate an no 2T.
it will be interesting to see if there is a noticeable difference reverting to just diesel! BM52
Post #102847 27th Nov 2011 8:09pm
spudfan
Ireland
Picked up a 1 litre bottle of Tesco motorcycle oil 2 stroke, today for �4.99. Does not say if it is mineral or synthetic but at that price I'd guess mineral based.Says it is formulated from "selected base oils" and is FB spec.Anyone know for sure?. Have been using Castrol Activo but decided to dumb down to the FB spec.
Could get a 5 litre bottle of chainsaw lubricant at the local co-op for �8.99, but there is no info on it whether it is mineral or synthetic or what spec it is. Just says "anti-fling" for chainsaws. Anyway gave it a miss owing to the lack of info. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #103207 28th Nov 2011 11:04pm
T1G UP
google the specs, there a standard. FB is low ash mineral from my memory of last search. cheaper the better i'd say.
I'll sling some in the new one tomorrow
Post #103210 28th Nov 2011 11:10pm
spudfan
Ireland
Yep, have been googling away but cannot get exact brand matches. From what I have found out is that for �8.99 for 5 litres it has to be mineral based but hard to know the specs. It can hardly be FC spec but is there anything lower than FB sold on the market? 1982 88" 2.25 diesel
Post #103219 29th Nov 2011 12:15am
T1G UP
yes theres a FA
look at this link
http://www.7thgear.net/7thGear/Default.aspx?tabid=27
best deal i've found
http://www.ebay.co.uk/itm/290481665920?ssP...906wt_1344
Post #103221 29th Nov 2011 12:20am
spudfan
Ireland
Yep saw that, just wondering if the chainsaw oli is 2 stroke. 1982 88" 2.25 diesel
Post #103222 29th Nov 2011 12:23am
