![]() | Home > Puma (Tdci) > 2 Stroke oil in diesel. |
pushrod Member Since: 11 Nov 2011 Location: NSW Posts: 3 ![]() ![]() |
i took the plunge today and put 2SO in my 2011 Puma for the first time...
after only 50 kms i sounds noticeably quieter .. lets see how it sounds first thing in the morning on cold start.. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
Thank you for that, I will stick with the 2 stroke. I presume the Tesco stuff is o.k. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
As above chain oil not 2stroke.
Andy |
Cheers for that. Will be sticking to the bottles where it actually says 2 stroke! Just trying to get the cost down as I use it every fill up. 1982 88" 2.25 diesel
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
30 miles on 2 stroke so far.Its definately quieter.
![]() 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
TheTechnobear Member Since: 28 Jan 2011 Location: Guadix, Spain Posts: 54 ![]() ![]() ![]() |
anyone know anything about Castrol 2T oil in red bottle ?
see here i cant find it on castrols website, the packaging says 2 Stroke, JASO FB... but doesnt say if its mineral or synthetic. i wondering if its old stock? unfortunately, its all they have in my local BP... anyone seen / used it before? |
FB is what you want |
Ok, it's FB so sounds like I should be good to give it a go
![]() I was wondering about doing a before and after test... As next week my nanocom should be arriving in Spain ![]() Is there anything we measure to see if it improves? Any theories on changes we might expect? My plan would be to do a test run, to try to keep things comparable ... and try to do on similar days weather/temp wise. |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
25L semi-synth 2T £50
![]() http://www.tines.co.uk/rock-oil-tines.htm 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy ![]() |
