Home > Maintenance & Modifications > Alive ATRIC now supports Td5
Alive Tuning
Good news for Td5 owners... We have now managed to get ATRIC working with all EU3 Td5 models! Very Happy
Even better is the price... An ATRIC module for Td5 for just 395+VAT.
(Before anyone asks, That is the Forum Price!) Mr. Green
Post #103047 28th Nov 2011 12:25pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Pardon my ignorance, but does that price include a map or is it just for the unit?
Thanks
Post #103051 28th Nov 2011 12:28pm
Alive Tuning
The price does indeed include a custom remap.
You get the same level of service as you would with any of our other tuning products.
Post #103053 28th Nov 2011 12:30pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Gary, for those of us that have a Td5 remap from you already, is there a deal to be had for the unit with our custom + original LR map pre-loaded ? Mr. Green Jon - 110 td5 [sold]. Currently Defenderless.
Post #103062 28th Nov 2011 12:59pm
Alive Tuning
Of course there are deals to be had. The only issue is that ATRIC first needs to read the original map file from your car, and will store this in its memory as an 'original'. In your case however, the map on your car is far from original!
The only way I can see of doing this is if I configure the units here, by making a clone of your ECU on the bench. All achievable, but quite time consuming. Neutral
Post #103067 28th Nov 2011 1:14pm
robpenrose
I could be very tempted in the new year.
So would this be a through the post job, then we would load the map ourselves? or would we need to come up and have the map made up first?
Is it two maps thats can be stored? original + Map or original + 2?
Cheers Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #103075 28th Nov 2011 1:34pm
party monkey
Understood, thanks Gary. I'm not in a rush to do this and I don't want you going to all that effort to clone my ECU when you could be doing better things. I'll maybe pop up to you guys at some point next year. I still need to sample the fish and chips!
Will PM you nearer the time Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #103081 28th Nov 2011 1:48pm
Alive Tuning
ATRIC remapping is done through the post, and is available to anyone around the world. As long as you have access to a Windows PC, the rest is simple.
Tuning as always, will be tailored to your needs, and so I would like to think that I could get it right first time. I have tuned a few Td5's in my time! However, should any fine tuning to the mapping be required, then of course I will be happy to oblige.
It's useful if you decide to upgrade to a bigger intercooler etc in future too, as I can easily send out a revised map file to you. Very Happy
Post #103082 28th Nov 2011 1:49pm
robpenrose
Thanks for the extra info. I will probably be in touch in the new year to discuss some options. Smile Current:D4 HSE
Gone: BMW Z4MC
Post #103086 28th Nov 2011 1:59pm
landy andy
Mmmmmmm. Interesting,
What are the advantages of this system over a one off remap????
Will Be in touch, Thumbs Up Thumbs Up
Well done Bow down Bow down
Andy
Post #103178 28th Nov 2011 8:40pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Thanks Gary, certainly on my to-do list at some point in the future
stoker Cool 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #103231 29th Nov 2011 6:36am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
td5
i see its a fault code reader as well ,how does it match up to the nanocom.?
Post #103518 30th Nov 2011 1:25pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I have a nanocom would it be cheaper to have the map file sent out to put it on via nanocom instead of buyinh the ATRIC unit? what are the pros and cons of this?
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #103584 30th Nov 2011 6:10pm
Alive Tuning
ATRIC will allow you to quickly change from standard tune, to performance tune. It will also allow you to read and clear engine management fault codes. To be honest, on a Td5, this is all you need it to do.
If you have a nanocom already then it would pay to use that. The ecu programming takes much longer, and so there is a greater risk of programming failure than there would be with ATRIC. Shocked
Post #103722 1st Dec 2011 12:40am
Lorryman100
Go for the Atric unit for installing the remap files as it tests the map files before and after loading. If you still fancy using the nanocom go onto AULRO.com and have a look in the Electronics section for some real woe stories on nanocom programming that has gone wrong.
And a big plus for the Atric unit is the support and back up you will receive as an Alive customer. Thumbs Up
Post #103724 1st Dec 2011 12:45am
