Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Joolroper Member Since: 02 Oct 2022 Location: Bristol Posts: 25 |
Only stop/start holds memory. Driver assistant still resets.
7th Apr 2024 6:35pm |
marcd3301 Member Since: 11 May 2023 Location: Telford Posts: 22 |
Have tried ACC on my wife's Defender, and although I have all functionality, I now have an Adaptive Speed Limited (feature not available) fault. Has anybody else come across this, or have any ideas as to the issue? I only changed those items listed previously:
EUCD 023 Multican 580 Multican 809 Multican 712 All other mods (dynamic, ATPC, back door release etc) no issues at all. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
8th Apr 2024 11:58am |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 42 |
Im struggling to get the activation code for my new G4, could be an old age thing starting but I can’t remember it being overly complicated getting the IID Tool to work on the discovery.
Any advice most welcome Chris. MY24 X-Dynamic HSE D250 110, Santorinis Black, Matrix LED headlights, Dark grey cross car beam, Air suspension, HUD, Secure Tracker pro, Wheel arch protection, Deployable tow bar. |
8th Apr 2024 4:16pm |
Kobevs Member Since: 13 Jan 2024 Location: Mechelen Posts: 4 |
I did dynamic mode and config TR. Also found how to do auto settings and that also seems to work. |
9th Apr 2024 9:44pm |
I can't do ATPC. First I got Emergency braking warning. That went away. But I can't do the double push on the button to activate it.
Does anyone have the codes for ATPC? Thanks. |
10th Apr 2024 12:04pm |
Got everything working.
Dammitdeano Member Since: 07 Nov 2023 Location: Brisbane Posts: 12 |
Question:
G4 should arrive tomorrow. Wanting to add adaptive cruise, TR2, Config TR, ATPC and Dynamic Mode. Are any of the above dependant on the rear locking diff? My Defender doesn’t have one and I just want to be sure. |
15th Apr 2024 12:02pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1396 |
No none of those need the rear diff to work Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Apr 2024 12:23pm |
Cheers bud.
15th Apr 2024 12:35pm |
Mikemillar89 Member Since: 30 May 2013 Location: Cheshire Posts: 17 |
Can you stop the car from shutting off at a period of idle?
15th Apr 2024 3:03pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2566 |
Do you mean the stop/start function where the engine stops while you are stationary? You can set it to remember the selection.
So you turn it off with the button on the console and it stays off, you don't have to turn it off every time you use the vehicle. |
15th Apr 2024 3:52pm |
zhihong.james Member Since: 14 Apr 2022 Location: Calgary Posts: 7 |
Played with the new G4 unit on my 2023.5 110X yesterday. I was able to enable to active the park assist with the CCF configuration has been posted here earlier.
EUCD-059 Parking Assistance PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera With Park Assist Camera EUCD-140 Pdcautoactivationmenu With PDC Auto Activation Menu MultiCAN-469 PDCAutoActivation Default off configuarable MultiCAN-500 PDCBtnFCIM Fitted MultiCAN-602 PDC 10 Channel fitted (Park Assist) MultiCAN-786 Park Assist Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) the system actives and finds parking spot without any issues. BUT, the "start" button was greyed out, cannot be pressed on the touch screen. So, cannot get the park assist work, same as other members have reported earlier. |
15th Apr 2024 4:29pm |
No, if your not in the car but want to leave it running. After a lenght of time it switches itself off. |
15th Apr 2024 5:00pm |
