Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 82 of 110 <123 ... 818283 ... 108109110>
Joolroper
United Kingdom 2012 Defender 90 Puma 2.2 X-Tech LE Orkney Grey
Only stop/start holds memory. Driver assistant still resets.
Post #1030871 7th Apr 2024 6:35pm
stevemfr
France
ardevd wrote:
Can anyone tell me whether id need a per-VIN license for the IIDtool BT if all I want is readouts of sensor data (live)? The product page is a bit ambiguous on this point. I’d love to have a Bluetooth based tool that I can have with me and plug into different vehicles and view sensor data.
Hi ardevd,
General diagnostics are not VIN locked, only special programming functions such as EAS and CCF, etc.
You can perform all diagnostic functions on all vehicles your IIDTool covers. Please be aware that due to it's hardware, the G4 will not function on the 02-09 L322.
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1030919 8th Apr 2024 8:56am
marcd3301
Have tried ACC on my wife's Defender, and although I have all functionality, I now have an Adaptive Speed Limited (feature not available) fault. Has anybody else come across this, or have any ideas as to the issue? I only changed those items listed previously:
EUCD 023
Multican 580
Multican 809
Multican 712
All other mods (dynamic, ATPC, back door release etc) no issues at all. Cheers Marc
20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted.
24MY Defender 110 D300 XS, Santorini Black.
Post #1030940 8th Apr 2024 11:58am
Chris S
Activation code
Im struggling to get the activation code for my new G4, could be an old age thing starting but I can’t remember it being overly complicated getting the IID Tool to work on the discovery.
Any advice most welcome
Chris. MY24 X-Dynamic HSE D250 110, Santorinis Black, Matrix LED headlights, Dark grey cross car beam, Air suspension, HUD, Secure Tracker pro, Wheel arch protection, Deployable tow bar.
Post #1030967 8th Apr 2024 4:16pm
Kobevs
Belgium
benrh wrote:
I was able to activate Auto Terrain Response on my 2024 110 X-Dynamic with the new GAP IID G4 Bluetooth. Question… how do you know it actually works and isn’t simply displaying that it is in Auto 😂
I did dynamic mode and config TR. Also found how to do auto settings and that also seems to work.
Post #1031115 9th Apr 2024 9:44pm
Kobevs
Belgium
I can't do ATPC. First I got Emergency braking warning. That went away. But I can't do the double push on the button to activate it.
Does anyone have the codes for ATPC? Thanks.
Post #1031165 10th Apr 2024 12:04pm
Kobevs
Belgium
Got everything working.
Post #1031166 10th Apr 2024 12:04pm
Dammitdeano
Australia
Question:
G4 should arrive tomorrow.
Wanting to add adaptive cruise, TR2, Config TR, ATPC and Dynamic Mode.
Are any of the above dependant on the rear locking diff? My Defender doesn’t have one and I just want to be sure.
Post #1031622 15th Apr 2024 12:02pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
No none of those need the rear diff to work Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1031625 15th Apr 2024 12:23pm
Dammitdeano
Australia
Cheers bud.
Post #1031628 15th Apr 2024 12:35pm
Mikemillar89
Can you stop the car from shutting off at a period of idle?
Post #1031646 15th Apr 2024 3:03pm
Mikemillar89
Post #1031647 15th Apr 2024 3:03pm
lightning
Do you mean the stop/start function where the engine stops while you are stationary? You can set it to remember the selection.
So you turn it off with the button on the console and it stays off, you don't have to turn it off every time you use the vehicle.
Post #1031655 15th Apr 2024 3:52pm
zhihong.james
Canada
Park Assist
Played with the new G4 unit on my 2023.5 110X yesterday. I was able to enable to active the park assist with the CCF configuration has been posted here earlier.
EUCD-059 Parking Assistance PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera With Park Assist Camera
EUCD-140 Pdcautoactivationmenu With PDC Auto Activation Menu
MultiCAN-469 PDCAutoActivation Default off configuarable
MultiCAN-500 PDCBtnFCIM Fitted
MultiCAN-602 PDC 10 Channel fitted (Park Assist)
MultiCAN-786 Park Assist Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
the system actives and finds parking spot without any issues. BUT, the "start" button was greyed out, cannot be pressed on the touch screen. So, cannot get the park assist work, same as other members have reported earlier.
Post #1031660 15th Apr 2024 4:29pm
Mikemillar89
No, if your not in the car but want to leave it running. After a lenght of time it switches itself off.
Post #1031666 15th Apr 2024 5:00pm
