Home > In Car Electronics > Pin terminal crimp tool / connectors help please.
mcma1
I have some switches I need to get up and running, all Land Rover, but can anyone point me to a starter kit that would include the terminals and also the crimping tool? Thanks
https://www.mudstuff.co.uk/products/land-r...1573519445 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1030943 8th Apr 2024 11:25am
Martin
Site Admin
Well firstly I do the connector kits, complete with terminals, cheap than them Wink
https://fnltd.co.uk/shop/5-way-defender-sw...6-p71.html
You can either buy the 100% correct manufacturer crimp tool, a compatible tool or a generic tool. Depends on budget.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1030945 8th Apr 2024 11:41am
mcma1
Thanks Martin, I will order what I need now. Dont suppose you have a link to a compatible generic tool? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1030947 8th Apr 2024 11:44am
Martin
Site Admin
For these, I would go with
https://www.amazon.co.uk/Hozan-P-706-Barre...B002TKG11G
You do the wire and the insulation separately, but a bit of practice on some scrap wire and spare terminals - you get one per connector from me, but I'm sure I might include a few more Wink - will soon find the correct positions to use.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1030948 8th Apr 2024 11:46am
mcma1
Thanks, just placed my order with you. Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1030949 8th Apr 2024 11:50am
Martin
Site Admin
Received and I'll get those out today Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1030950 8th Apr 2024 11:51am
mcma1
Hi Martin,
What is the typical gauge of wire used in the LR switches?, I only have off cuts built up over the years and would need to add some to the supplies..
Thanks
Andy Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1031107 9th Apr 2024 7:37pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Martin would there be such a thing as a female plug version of these so I could make an extension loom for some switches
Post #1031148 10th Apr 2024 9:05am
Martin
Site Admin
https://fnltd.co.uk/shop/defender-2002-201...-p124.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1031149 10th Apr 2024 9:06am
shanecl
Thanks Martin, I'll figure out how many i need and place the order Very Happy
Shane
Post #1031150 10th Apr 2024 9:11am
Martin
Site Admin
mcma1 wrote:
Hi Martin,
Thanks
Andy
Generally, 0.5mm2 is used for most switches as they don't directly switch their respective devices, they are signal wires or low current for illumination.
The heated seat switches do switch directly and have 1.0mm2 input and 0.75mm2 output wires.
And although it only switches a signal, the air con switch factory wiring has 1.0mm2 in/out and ground wires.
Different connectors to these, but the electric window and hazard switches again have larger wires as they switch directly.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1031153 10th Apr 2024 9:27am
