![]() | Home > In Car Electronics > Pin terminal crimp tool / connectors help please. |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2938 ![]() ![]() |
I have some switches I need to get up and running, all Land Rover, but can anyone point me to a starter kit that would include the terminals and also the crimping tool? Thanks
https://www.mudstuff.co.uk/products/land-r...1573519445 Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6643 ![]() ![]() ![]() |
Well firstly I do the connector kits, complete with terminals, cheap than them
![]() https://fnltd.co.uk/shop/5-way-defender-sw...6-p71.html You can either buy the 100% correct manufacturer crimp tool, a compatible tool or a generic tool. Depends on budget. ![]() ![]() |
Thanks Martin, I will order what I need now. Dont suppose you have a link to a compatible generic tool? Andy
For these, I would go with
https://www.amazon.co.uk/Hozan-P-706-Barre...B002TKG11G You do the wire and the insulation separately, but a bit of practice on some scrap wire and spare terminals - you get one per connector from me, but I'm sure I might include a few more ![]() ![]() ![]() |
Thanks, just placed my order with you.
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Received and I'll get those out today
Hi Martin,
What is the typical gauge of wire used in the LR switches?, I only have off cuts built up over the years and would need to add some to the supplies.. Thanks Andy Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 518 ![]() ![]() ![]() |
Martin would there be such a thing as a female plug version of these so I could make an extension loom for some switches |
https://fnltd.co.uk/shop/defender-2002-201...-p124.html
Thanks Martin, I'll figure out how many i need and place the order
![]() Shane |
Generally, 0.5mm2 is used for most switches as they don't directly switch their respective devices, they are signal wires or low current for illumination. The heated seat switches do switch directly and have 1.0mm2 input and 0.75mm2 output wires. And although it only switches a signal, the air con switch factory wiring has 1.0mm2 in/out and ground wires. Different connectors to these, but the electric window and hazard switches again have larger wires as they switch directly. ![]() ![]() |
