Home > Off Topic > Clearing silt from drains |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17383 |
Use your hand, or a milk carton with the top cut off.
5th Apr 2024 2:32pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 462 |
Screw an old saucepan to a suitably long piece of wood? Perhaps chop about with a grinder!
5th Apr 2024 2:33pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 783 |
Unfortunately it is out of arm's reach with a milk carton, at least 1m deep.
Like the saucepan idea! Thanks BORG - Bucks & Oxon 4x4 Response Group |
5th Apr 2024 2:41pm |
Milk carton on a broom handle would be the way I went.
5th Apr 2024 3:03pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2004 |
Send a small child down the hole with a bucket....opps your not allowed to do that any more
5th Apr 2024 3:23pm |
Not openly anyway
5th Apr 2024 3:56pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3287 |
https://thehireman.co.uk/product/gully-scoop/ or you can buy one for around ยฃ80. WARNING.
This post may contain sarcasm. |
5th Apr 2024 4:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
UPVC / PVC Rigid pipe, just cut it to suit the size needed.
Maybe a little bit annoying to cut, but should work, just get a size a bit smaller than the original bore or multiple sizes. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
5th Apr 2024 6:28pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Thatโs a trade secret Steve
I have some 4inch ducting pipe for 110 underground drainage, 150 for 6 inch and 200 for 8 โฆ.. all cut around 250 long with a hole in the top and a broom handle stuck through, washer and screw through the bottom , a bit of Gaffer tape on the end seals it up, works a treat failing that a wet/pond vac will do the job |
5th Apr 2024 8:14pm |
Oops
Good to see you on here Jim. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
6th Apr 2024 7:05pm |
Thanks for the suggestions guys. Will see what I can fashion together next week. BORG - Bucks & Oxon 4x4 Response Group
6th Apr 2024 7:30pm |
