![]() | Home > Off Topic > Clearing silt from drains |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17558 ![]() ![]() ![]() |
Use your hand, or a milk carton with the top cut off.
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 504 ![]() ![]() ![]() |
Screw an old saucepan to a suitably long piece of wood? Perhaps chop about with a grinder!
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 798 ![]() ![]() |
Unfortunately it is out of arm's reach with a milk carton, at least 1m deep.
Like the saucepan idea! Thanks BORG - Bucks & Oxon 4x4 Response Group ![]() |
Milk carton on a broom handle would be the way I went.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2110 ![]() ![]() |
Send a small child down the hole with a bucket....opps your not allowed to do that any more
Not openly anyway
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3345 ![]() ![]() ![]() |
https://thehireman.co.uk/product/gully-scoop/ or you can buy one for around ยฃ80. WARNING.
This post may contain sarcasm. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20588 ![]() ![]() |
UPVC / PVC Rigid pipe, just cut it to suit the size needed.
Maybe a little bit annoying to cut, but should work, just get a size a bit smaller than the original bore or multiple sizes. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
Thatโs a trade secret Steve
![]() I have some 4inch ducting pipe for 110 underground drainage, 150 for 6 inch and 200 for 8 โฆ.. all cut around 250 long with a hole in the top and a broom handle stuck through, washer and screw through the bottom , a bit of Gaffer tape on the end seals it up, works a treat ![]() |
Oops
![]() ![]() Good to see you on here Jim. ![]() Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
Thanks for the suggestions guys. Will see what I can fashion together next week.
