Home > Off Topic > Clearing silt from drains
mini Anaconda
I'm currently cleaning a built up of dirt/silit/sludge from some drains. Ive got all of the big stuff out with a hand held post hole digger but the sludge just falls through this.
I need a scoop to put down the drain similar to the photo below to bring the sludge up but I'm struggling to find anything, other than tools from America which are very expensive. Tool pictured below is 150 dollars!
Can anyone help?
Many thanks Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #1030649 5th Apr 2024 3:11pm
Use your hand, or a milk carton with the top cut off.
Post #1030658 5th Apr 2024 3:32pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Screw an old saucepan to a suitably long piece of wood? Perhaps chop about with a grinder!
Post #1030659 5th Apr 2024 3:33pm
mini Anaconda
Unfortunately it is out of arm's reach with a milk carton, at least 1m deep.
Like the saucepan idea! Thanks BORG - Bucks & Oxon 4x4 Response Group
Post #1030662 5th Apr 2024 3:41pm
geobloke
Milk carton on a broom handle would be the way I went. Thumbs Up
Post #1030665 5th Apr 2024 4:03pm
Ianh
Send a small child down the hole with a bucket....opps your not allowed to do that any more Rolling with laughter Rolling with laughter
Post #1030668 5th Apr 2024 4:23pm
geobloke
Not openly anyway Rolling Eyes
Post #1030671 5th Apr 2024 4:56pm
Zed
https://thehireman.co.uk/product/gully-scoop/ or you can buy one for around £80. WARNING.
Post #1030678 5th Apr 2024 5:48pm
UPVC / PVC Rigid pipe, just cut it to suit the size needed.
Maybe a little bit annoying to cut, but should work, just get a size a bit smaller than the original bore or multiple sizes. WeWillWin🇬🇧🇺🇸
Post #1030683 5th Apr 2024 7:28pm
barbel jim
That’s a trade secret Steve Laughing
I have some 4inch ducting pipe for 110 underground drainage, 150 for 6 inch and 200 for 8 ….. all cut around 250 long with a hole in the top and a broom handle stuck through, washer and screw through the bottom , a bit of Gaffer tape on the end seals it up, works a treat Whistle failing that a wet/pond vac will do the job
Post #1030692 5th Apr 2024 9:14pm
Oops Whistle Laughing
Good to see you on here Jim. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1030762 6th Apr 2024 8:05pm
mini Anaconda
Thanks for the suggestions guys. Will see what I can fashion together next week. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #1030766 6th Apr 2024 8:30pm
