![]() | Home > Off Topic > Clearing silt from drains |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
Use your hand, or a milk carton with the top cut off.
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 519 ![]() ![]() ![]() |
Screw an old saucepan to a suitably long piece of wood? Perhaps chop about with a grinder!
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 800 ![]() ![]() |
Unfortunately it is out of arm's reach with a milk carton, at least 1m deep.
Like the saucepan idea! Thanks BORG - Bucks & Oxon 4x4 Response Group ![]() |
Milk carton on a broom handle would be the way I went.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2146 ![]() ![]() |
Send a small child down the hole with a bucket....opps your not allowed to do that any more
Not openly anyway
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3349 ![]() ![]() ![]() |
https://thehireman.co.uk/product/gully-scoop/ or you can buy one for around £80. WARNING.
This post may contain sarcasm. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
UPVC / PVC Rigid pipe, just cut it to suit the size needed.
Maybe a little bit annoying to cut, but should work, just get a size a bit smaller than the original bore or multiple sizes. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
That’s a trade secret Steve
![]() I have some 4inch ducting pipe for 110 underground drainage, 150 for 6 inch and 200 for 8 ….. all cut around 250 long with a hole in the top and a broom handle stuck through, washer and screw through the bottom , a bit of Gaffer tape on the end seals it up, works a treat ![]() |
Oops
![]() ![]() Good to see you on here Jim. ![]() ⛽️🛢️⚙️🧰💪 |
Thanks for the suggestions guys. Will see what I can fashion together next week.
