Home > Puma (Tdci) > 2.4 engine rattle - solved
Page 3 of 3 <123
Topvaruk
Slovakia 2010 Defender 90 Puma 2.4 ST Aintree Green
I thought they were one of the better ones
I am sure I also read on their fleebay listings that the fuel system needs to be flushed and samples taken etc
Probably outside the ability of a home mechanic - leaving the warranty void.
I am using a company from Germany called dieselfix Neuss - also on the bay.
Website looks impressive, 48hr delivery to Slovakia. They hold a 200 euro deposit until I return my old ones.
Wanted a EU based firm as the shipping of items for repair back and forth to the UK has now become a real PITA - Brexit. 2010 90 LHD soft top
2010 110 XS
1985 90 soft top
Post #1028593 19th Mar 2024 7:12am
Topvaruk
Fixed
So it seems injectors were the problem.
Got it back today without the noise.
My local dealer couldn’t get the pilot learn or coding of the injectors to work.
I persevered with my nano.
What did I lean …….?
Well, code them one at a time …. If I entered all 4 and did a WRITE it wouldn’t spit it out - error 31
One by one was ok …. And then the pilot learn also worked. Before I managed to get the coding to work the learn function was also having a fit and quite literally computer says no!
Wise words on where to source parts - I tend head for the same as LR fitted but I do the leg work to buy from elsewhere. Denso kit is easily available but the prices can vary hugely. I will only use Denso for such things a VCV and injectors.
Thanks for your warm support and advice chaps 2010 90 LHD soft top
2010 110 XS
1985 90 soft top
Post #1028793 20th Mar 2024 6:01pm
spudfan
Ireland
Thumbs Up Congratulations, it has been a trying journey. You issues here will no doubt be of benefit to other members in the future. Enjoy your motoring! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1028796 20th Mar 2024 6:07pm
NickMc
I’ll agree beware of reconditioned injectors. I buy mine from Merlin Diesel https://www.merlindiesel.com/
Also avoid eBay or aftermarket fuel valves they can be impossible to get to do pilot learns.
Post #1028797 20th Mar 2024 6:11pm
Waka56
Germany
Nice, I hope my injectors will have the same effect Rolling with laughter
Can you still drive it from A to B before recoding the injectors? Might have to send it to the garage for a relearn, would be nice if the car can get there without me pushing it haha Making my Defender great again. (Or trying to at least xD)
Post #1028798 20th Mar 2024 6:16pm
Topvaruk
I drove it home (less than 10km) without the coding or pilot learn. Was fine but you could hear it wasn’t quite right.
Unless you are doing a 100km trip then should be ok.
There are some good threads here that suggest maybe even it doesn’t need to be done as the ECU will figure it out, the coding and pilot simply shortcut the adjustment time.
I am not wise enough to know if that’s correct but it does seem to make some sense
One thing that you could do if you have access to a tool is just to do a relearn of the existing injectors. This made a huge difference to my car - wish I had done it sooner. I am supposing over 14 years and a lot of fuel, the calibration of the injectors drifts out
There is of course one downside to fixing a rattle …… and that is now I can hear other rattles that were disguised.
Maybe a louder radio is the solution! 2010 90 LHD soft top
2010 110 XS
1985 90 soft top
Post #1028801 20th Mar 2024 6:43pm
Waka56
Germany
Haha, I am a new owner, gonna take me months to get rid of all non normal noise Rolling with laughter Making my Defender great again. (Or trying to at least xD)
Post #1028820 20th Mar 2024 8:17pm
Page 3 of 3 <123
