![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Philipp1601 Member Since: 17 Feb 2023 Location: Borken Posts: 23 ![]() ![]() |
Hi dsstephens,
I have a feeling you tried to connect to the car with the engine running. I did the same because I wanted to save battery life. This did not work for me, too. Please try to use the IID-Tool with the car set to ignition on but without the engine running. This way it is possible to write data like CCF to the car. You could write Patrick from GAP Team an email about your problem: team@gap-diagnostic.com Greetings Philipp --------------------------------------- MY24 Defender 110 XS-Edition D250 Stealth Mod MY07 VW Multivan T5 Sport Edition D5 MY12 Mini R55 Cooper Works MY00 MB SLK 320 R170 Designo MY21 KTM 690 SMC-R |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 ![]() ![]() |
I’m going to chime in here and say that I always connect with the engine running. Both the G3 and now the G4 stop the engine when they need to. If you put your foot on the brake, the GAP tool will restart your engine and the transfer will fail. (My experience anyway).
dsstephens Member Since: 06 Jul 2022 Location: Hartwell Posts: 16 ![]() ![]() |
I will give it a shot but as a later poster indicates, it controls stop and start, and section 2.7 says it can be running. I'm happy to give it a shot anyway. thanks! 2020 SE First Edition 2004 Disco2 1986 110 V8 1971 Series IIa 88” |
I did pay special attention to keeping my giant feet away from the brake pedal. In any case, I'll try again this evening. 2020 SE First Edition 2004 Disco2 1986 110 V8 1971 Series IIa 88” |
muppetry Member Since: 31 May 2023 Location: NM Posts: 2 ![]() ![]() |
I also activated a G4, but without any of those issues. It successfully programmed ACC plus a couple of other CCF modifications. The ACC change did briefly result in an "emergency braking not available" message, but that went away after restarting the engine. Did you update the G4 firmware after activating the unit? |
ah, I updated it to Build 79, then went outside and activated it and started using it. Based on your (muppetry) message, I ran the updater again, and it updated now to Build 80.
Maybe that was it. Cheers! 2020 SE First Edition 2004 Disco2 1986 110 V8 1971 Series IIa 88” |
ding ding ding. AFTER activating was the key here, not before activating. Worked the charm. Cheers. 2020 SE First Edition 2004 Disco2 1986 110 V8 1971 Series IIa 88” |
Glad it worked, but when mine arrived, the updater told me I already had the latest and I activated without updating. A few days later an update was available. I should check again.
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
My G4 (already sent back my G3 to Canada) is arriving next week but I’ve been hit with a £59 charge by ups. Anyone else get charged?
coda0 Member Since: 07 Sep 2023 Location: Clearwater, Florida Posts: 5 ![]() ![]() |
It cost me about $45 to send my G3 back to Quebec.
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 61 ![]() ![]() |
Yep
![]() ![]() (I too sent my g3 back a couple weeks back) But we were made aware any charges we would be liable My 24 HSE X-Dynamic 90 Carpathian Grey Last edited by Down & Dirty on 15th Mar 2024 9:32am. Edited 1 time in total |
Cost me $17 usps. Delivered to GAP today.
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 ![]() ![]() |
Cost me £12 to send the G3 back and £0 for the G4. G4 was delivered Wednesday. Chuffed 👍👍
Cheers fella 👍🏻👍🏻 I’ve already activated the features using JetPro a few months back but have been afraid to tinker further as I only had the 3 day licence and I didn’t want any error codes. |
