Home > BMW Engine Conversions > M57 swap into the Red Baron
Page 4 of 7 <1234567>
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Shane, this thread has been so useful! I’m currently working on putting a M57N2 from a 2009 X5 E70 in to my 110, and was deliberating over the Blackbird P38 conversion or fitting aircon compressor and steering pump from an E90 - you’ve confirmed that’s the way to go!
(If I’d read this before buying a X5 as a donor then maybe I’d just have looked for a E90 330D instead!)
Do you have any photos of the turbo actuator rotated and the bracket? Does it clear the steering box now?
Post #1022070 21st Jan 2024 6:25pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi Carrotbay, ah thanks, that's good to here Very Happy .
I am getting a bracket made as I tried to drill different holes in the original and just wasn't working for me. I am getting a few brackets made but i don't have a price yet from the machine shop Big Cry . I have seen a few others make their own brackets rotating the actuator 180deg nearly but since I have access to this place was the quickest and easiest route for me.
I'll keep you updated
Shane
Post #1022364 24th Jan 2024 11:29am
Mj_pilot
 2011 Defender 110 Other SW Auto Indus Silver
Magic Shane! Cheers for the belt, pulley and tensioner info.
E90 seems to do the trick (haven’t started it yet).
Photo shows the belt id’s for anybody making the same mods.
shanecl wrote:
Here you go Very Happy
a lot of time has gone into trawling the drawings on bimmercat to figure stuff out Laughing
I've loads of updates to post, just been gallivanting in the Alps and sierra Nevada's Very Happy
Thanks MJ Very Happy
Post #1024888 16th Feb 2024 2:32pm
Mj_pilot
Carrotbay,
The turbo actuator on my install clears. It’s close but it clears. The plug housing touches the steering box but I may get away with it. Otherwise, just need to trim the housing a bit.
https://www.defender2.net/gallery/albums/u..._image.jpg
Post #1024889 16th Feb 2024 2:38pm
Mj_pilot
Post #1024894 16th Feb 2024 2:51pm
carrotbay
Mj_pilot wrote:
Carrotbay,
Thanks MJ - really useful
I got my engine in this week and I’m probably a few mm further forward as the actuator plug is very tight against the steering box. I’m going to space it back a little on it’s mounting bolts and that should do the trick.
Good to see the belts, just waiting for some bits to arrive and that should sort that. What are you doing for power steering hoses?
Post #1024971 17th Feb 2024 7:33am
shanecl
No problem MJ, looking good with the actuator, jammy Laughing still no sign of my bracket. i'm hoping next week
Post #1025297 20th Feb 2024 11:21am
shanecl
My friend done a sexy job on my turbo outlet, i got the flange from Darkside Developments and he then done a couple of piecuts and glued it together, plan is a 55mm 45Deg nice and level to go into the intercooler.
Post #1025305 20th Feb 2024 11:58am
shanecl
Also got around to wiring up my fuel gauge thanks to Martin for the help on where they go, want it looking OEM so replaced some conduit from the main loom and nice tidy finish
Post #1025307 20th Feb 2024 11:59am
shanecl
another little side project. I am running disco 2 axles and one of the nights i was installing the brake disc stone guards, had a great idea to run an M6 tap through the threads to clean them, i was wrecked tired and broke he tap inside one of the threads, ah well i'll fix it tomorrow. got another M6 tap to finish the 2 other holes and guess what broke that one, time for bed Rolling Eyes
I bought a new axle casing and was quicker and easier to buy the new defender brackets from YRM, same friend then welded them on for me. While i was doing this i got the HD diff guards from BlackBird industries so had to take the front axle out also Whistle , all sent for vapour balsting after welding and painted 2 pac black.
Installed my Pioneer 4x4 brake lines,
Post #1025308 20th Feb 2024 12:02pm
shanecl
Took a little break and went to the Fiacaill ridge in the cairngorms for a coffee.
Post #1025309 20th Feb 2024 12:03pm
shanecl
[quote="Mj_pilot"]
MJ see your pipe for the bottom radiator, the E53 X5 bottom pipe fits straight on and its minus the EGR cooler pipe. can get it on ebay for feck all
Post #1025323 20th Feb 2024 2:14pm
carrotbay
Shane / MJ I’m swapping out the power steering pump and air con pump on my E70 engine for 330D parts. Please can you help with the idler under the alternator / next to the tensioner? I bought the part below, but I don’t think it’s right as I think it needs to bolt through the alternator lower mount and the one supplied doesn’t. Do you have the part number you used?
Post #1025535 21st Feb 2024 7:50pm
shanecl
carrotbay, I did have to change that bolt, I think and I cant remember why. I'll have a look through orders and see
Post #1025577 22nd Feb 2024 10:17am
Mj_pilot
Power steering part numbers …
carrotbay wrote:
Mj_pilot wrote:
Carrotbay,
Post #1025783 24th Feb 2024 6:34am
