Home > My Defender > M57 swap into the Red Baron
Page 6 of 6 <123456
Mo Murphy
tuddy70 wrote:
carrotbay wrote:
Mj_pilot wrote:
Carrotbay,
The turbo actuator on my install clears. It’s close but it clears. The plug housing touches the steering box but I may get away with it. Otherwise, just need to trim the housing a bit.
Thanks MJ - really useful
I got my engine in this week and I’m probably a few mm further forward as the actuator plug is very tight against the steering box. I’m going to space it back a little on it’s mounting bolts and that should do the trick.
Good to see the belts, just waiting for some bits to arrive and that should sort that. What are you doing for power steering hoses?
Hi Carrotbay, regarding the power steering hoses I read that off the shelf 200tdi are a direct fit so could be worth a look to save a few quid, Ive noticed people offering a conversion for double the price of these Shocked
I used the original 200 tdi high pressure pipe tweaked to suit the pumps location and used just hose for the low pressure return, no fancy kit used.
50 Shades of Pennine Grey
Post #1026392 29th Feb 2024 6:15pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Weekend was spent mainly cleaning out the garage as it turned into a pure dump.
Garage cleaned and got to making the fuel lines, still no sign of my bracket which i sent off to be made mid December Rolling Eyes
Post #1027603 11th Mar 2024 12:42pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Hey Shane. What’s the brackets you’re waiting for? I’ve good contacts with laser cutters and CNCs. Happy to help if I can - shoot me a pm. 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #1027751 12th Mar 2024 7:50am
shanecl
Thanks Matt Very Happy , i gave him a quick call before replying and apparently he is waiting on a soft touch sensor, he promises me Monday the latest i will have them but this is the same fella that was looking out the window 2 weeks ago at them cutting it Laughing
If nothing arrives next week I'll take you up on the offer Very Happy
I'm getting bracket to;
mount fuel filter/pump
ECU box
Exhaust downpipe
Post #1027787 12th Mar 2024 1:10pm
Jason-SEK
 2008 Defender 110 Puma 2.4 SW Santorini Black
Hi Shane, which engine mounts you ended up using? Or you fabricated your own? Thanks a bunch
Post #1038786 30th Jun 2024 4:13pm
shanecl
Hi Jason,
I used 300tdi mounts that i welded in as it was originally setup for a V8. I bought them from MWmachines but he now has mounts that will work with the chassis Td5 ones so no cutting or welding Very Happy
Shane
Post #1038864 1st Jul 2024 11:46am
Jason-SEK
Thanks Shane. M57 running on a PUMA here and the concern is how to clear the steering box. I am checking with Mahker first as Dave has a point with engine sitting lower and flush. But then again, will it clear? 🤔
BTW- is your car running now? Any vibrations? How did you manage the DPF filter to ECU operation and connecting the external airbox?
Post #1038866 1st Jul 2024 12:12pm
shanecl
I know its no help but I got a new bracket made to essential flip the turbo actuator arm and now clears the steering box.
Yep finally running thank god Very Happy no vibrations, like a mouse heart ticking over. I got the EGR, DPF, Immob and EWS erased out of the ECU by Will at House of Torque.
Also which I haven't just done yet is, I bought a 535D rocker cover, these use a remote air box and air flow sensor. Plan is to fit this cover run a remote air filter and connect to a snorkel. Allisport make a M57 air filter housing but its not listed on their site
Post #1038871 1st Jul 2024 2:37pm
Jason-SEK
Appreciate it, Shane! Can you share the rocker cover part number? ...and do you still run the DPF for environmental and DMV purposes their in Ireland? Thanks a bunch
Post #1038874 1st Jul 2024 2:56pm
shanecl
Here's the part numbers, I see there's a few on Ebay
11128507607 / 11127812894 / 11128578811
My defender is 89 so thankfully its vintage and goes under a different set of guidelines then the newer vehicles Very Happy
Post #1038946 2nd Jul 2024 10:42am
Jason-SEK
Smart move, Shane!
And thanks for the part number.
Have you considered an E90 M57 306D5 oil sump as opposed to the E60 one. I understand the problem is the clearance, just wondering if I need to replace my E90 pan with an E60 upfront or not.
Post #1038957 2nd Jul 2024 1:32pm
shanecl
No problem Very Happy
I cant speak from experience but I say you should be fine with the E90 sump as long as its not X-Drive. Very Happy
Ive had a look and the E60 sump and E90 sump are different part numbers. Also be careful if you do change as you will need the matching pump and pickup tube
Post #1038961 2nd Jul 2024 2:25pm
JOW240725
Jason, welcome to D2N. Please consider starting your own build thread. Plenty of us would enjoy following the project. Thumbs Up James
Instagram @suffolk_rovers
Post #1038980 2nd Jul 2024 5:49pm
Jason-SEK
Sure. How do we tag Shane?🙃
Post #1038983 2nd Jul 2024 6:14pm
Page 6 of 6 <123456
