![]() | Home > BMW Engine Conversions > M57 swap into the Red Baron |
Mj_pilot Member Since: 24 Oct 2023 Location: Oz Posts: 10 ![]() ![]() ![]() |
Magic - thankyou.
I’m planning to take off for the transmission cooler but if I ditch that idea I’ll take your advice on board. Cheers. [quote="shanecl"]
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
Progress Shane ! Good to see ! Are you suffering some mission creep with the axles ...
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 522 ![]() ![]() ![]() |
Mo, i am the biggest procrastinator and overthinker you will ever come across
![]() Thanks Mo ![]() back on track, fitting fuel system tonight and got to get a lead for the PC so i can fill auto box and we should have some noise coming from it soon ![]() |
[quote="Mj_pilot"]Magic - thankyou.
I’m planning to take off for the transmission cooler but if I ditch that idea I’ll take your advice on board. Cheers. I was thinking of running a water cooler too for the trans but wasn't sure, pulled the trigger on a setrab so see how we go. The E60 530d cooler i was looking at and easy money on ebay |
I'll look forward to progress then 👍 Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
tuddy70 Member Since: 28 Aug 2016 Location: West Yorkshire Posts: 32 ![]() |
Awesome thread
Hi Carrotbay, regarding the power steering hoses I read that off the shelf 200tdi are a direct fit so could be worth a look to save a few quid, Ive noticed people offering a conversion for double the price of these ![]() |
Sorry Carrotbay, i didnt see the last bit asking about the power steering hoses.
I got some hydraulic pipes made up. I'll take a picture and send you the size and lengths of the hoses. They are pretty short as the pump is right beside the box. I will do it this evening or Thursday ![]() |
So this is what £200 pounds of air con fittings look like
![]() ![]() Click image to enlarge I was struggling with the air con as they use a different type of fittings and trying to get my head around it. Finally have it cracked and plan is to machine a new block with threaded fittings that connects to the evaporator and then buy an Eaton hose kit and make the hoses myself, Heading to machine shop Thursday to see how much it'll be to machine the block and maybe make a couple |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
i just bought a kit for ac hoses to replace pipes on my 2,4 with ac, m57n2 being fitted Cheers
Where did you get it jst
Shane |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 508 ![]() ![]() |
I think Marcus does the evaporator adaptor
Thanks Linds,
I got the large compressor fitting and the condenser fitting off him. Shane |
Marcus Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
