Home > Puma (Tdci) > Shocks
Page 5 of 9 <123456789>
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
We know that weight does make them ride much better, but there still must be a set-up than can provide a better ride, and cope with additional weight when required - after all most people-carriers, even mini-buses do?
Fishrider - I'm sure you've considered this, and maybe secured them, but I'd be a bit wary of carrying your gym weights around just for the sake of it - you wouldn't want them flying around in the event of an accident...
And another thought - the 2011 MYs are classed as commercial due to the weight carrying capacity aren't they? I know it's never going to get noticed, but would putting less HD springs on technically effect this?
Post #102188 24th Nov 2011 11:49am
Are progressive springs still available? I'm sure 110 sw's used to be fitted with them at one point Confused Darren
Post #102195 24th Nov 2011 12:56pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
AFAIK, most new 110s are fitted with progressive rate springs as standard. e.g. The RKB500300 springs are 270/315/406
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #102205 24th Nov 2011 2:41pm
fishrider
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Keswick Green
Just got this back from a famous west country 4x4 firm.
Hello,
We can only offer you heavy duty or raised suspension for your vehicle.
There is nothing in our catalogue of parts that will reduce the spring rate of the original springs.
Sorry we cannot be more help at this time
Regards,
Pretty frustrating , not even willing to discuss it any further. This is the third response like this in 24 hrs . I can't be the only person to inquire about this sort of thing. I live in England not the Rift Valley.
ADS 90 : The weights are only one deep and are on none slip rubber matting behind the second row. I see what your saying though. Have no idea about the commercial classification...I know I'll lose my warranty if i do this. 110 HT TD5 - 110 XS SW Puma
Post #102208 24th Nov 2011 3:31pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Went thru similar discussions with the usual suppliers of suspension. Only Extreme 4x4 got back to me with a 'yes we can , now what do you want'. But a few comments on here were not that complimentary, no idea why.
In the meantime I've had a set of Bilstein B6 fitted (thanks to Gary and Jake at Alive) which has improved the ride movement massively, so while still a firm ride its more controlled and not harsh.
After Christmas I'll restart the hunt for the springs again. I'm sure I've seen another firm doing bespoke springs for Defenders and I've an idea of the rate I want (on a 90) based on all the comments off other forums, that and the excessive ( for what I need) rating on the std springs and discrepancy front to rear.
I did notice that many talk about fitting police spec springs from discoverys, but with it comes a increase in height, which is not what I'd be after.
Stu
Post #102210 24th Nov 2011 4:10pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
No one ever responded as to who makes the factory shock. Just curious.
Post #102241 24th Nov 2011 6:53pm
fishrider
Not sure about the factory spring maker ?
From what I've read else where you need to adapt a 110 to take springs for Discovery and Range Rover as they're different diameter. 110 HT TD5 - 110 XS SW Puma
Post #102327 24th Nov 2011 10:42pm
mick
Thud chaps at the end of the day it's a Defender maybe you should have got a soft roader like a Rav 4 Rolling with laughter
Post #102332 24th Nov 2011 10:49pm
Ads90
mick wrote:
Thud chaps at the end of the day it's a Defender maybe you should have got a soft roader like a Rave 4 Rolling with laughter
Yaaaaaaawwwwn
Post #102344 24th Nov 2011 11:21pm
mick
Yyyyyaaaaaaawwwwwwwnnnnnnn
Indeed 5 pages on springs and shocks Banging Head Banging Head Ner Ner Ner Ner
Post #102352 25th Nov 2011 12:08am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Off Topic Which are the best headlamp bulbs Idea Idea
6 pages later BM52
Post #102354 25th Nov 2011 12:17am
fishrider
That's a fair point , it is a long post . Maybe i should have brought a road car like a jag estate car and turned my TD5 into a big boys tonka toy ? Just thought I'd try and shed some light on why people aren't bothered by ride quality. There's enough posts on everything else Rolling Eyes 110 HT TD5 - 110 XS SW Puma
Post #102358 25th Nov 2011 1:09am
Ads90
The title of the thread says shocks.
It's a forum discussion about shocks.
If you have no interest in the subject, maybe, duh - don't read it... and at the very least have the courtesy not to troll it... Rolling Eyes
I now see the prejudice you mentioned Fishrider & Honker, I guess this topic is now closed.
Nice work.
Post #102411 25th Nov 2011 11:55am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Had Land rover progressive springs on my last 110 with Koni Shox and it also had heavy duty roll bars, very smooth ride with very little body roll.
Will be installing again on my current 110 DC once engine and gearbox get sorted. Rolling Eyes
I have always found the genuine Lr springs good and upgrade with a good set of shox.
N.
Post #102426 25th Nov 2011 1:23pm
Graham S
Changed the springs and dampers on my 2010 110 XS station wagon finding the original setup not ideal for me.
Fitted Bilsteins all around and Land Rover HD springs. NRC6389 both sides at the rear and NRC9448/9 at the front.
I have a mantec winch bumper with Warn winch. Vehicle sits level, The ride is firm, but more comfortable and controlled than it was 'out of the box'. Very pleased with the setup and works well on and off road. Thumbs Up
Post #102501 25th Nov 2011 7:49pm
