![]() | Home > In Car Electronics > Defender puma alarm upgrade |
WestCountryPete Member Since: 30 Sep 2023 Location: Wiltshire Posts: 43 ![]() ![]() ![]() |
Someone with more knowledge than me will correct me if I’m wrong, but if you’ve got the sensors and the lights flash, it sounds like you may have an alarm already. It could just be a BBUS issue (battery backup sounder). I think it can fail after a period of time.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2161 ![]() ![]() |
To aid answering your question.
What vehicle do you have ? What year ? Does it have central locking? Depending on year you will have either a 10AS or an ALM unit fitted and potentially a BBUS (Battery Back Up Sounder) fitted. Here are some docs on how these alarm units can be configured with a Nanocom diagnostics tool including the settings available. 10AS https://www.nanocom-diagnostics.com/upload...0Guide.pdf ALM https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 141 ![]() ![]() |
Thank-you for replying.
It's a 2008 defender puma 2.4 non central locking. |
Morning,
Out of interest whereabouts is the Siren on the car? i'll have a look |
In its standard location the BBUS is fitted behind the nearside front headlight. However for security reasons it may have been relocated.
Ill be interested now to have a look..... just seems odd we have the sensors- and when the door is opened and the lock button on the fob has been pressed all the light start flashing
This may be helpful:
https://www.defender2.net/forum/post593446.html |
