Home > Puma (Tdci) > Washer jets
Page 4 of 5 <12345>
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Got the little blighters off, then proceeded to drop, not one but two M8 nuts into parts unseen down the back of the dash attempting to tighten up the replacement washer jet. Screwfix first thing. What a palaver. Should’ve just put up with the woeful trickle of water the original reluctantly deigned to skoosh vaguely in the windscreens direction.
Post #811387 21st Jan 2020 10:34pm
It’s a difficult bloomin spot I know!
It would ha e been useful to have been able to get a spanner in there without removing the bracket but you can’t.
If you put you hand up under the lower dash area where you have carpet or matting. Do t be surprised if you find those nuts as they will often get right to the bottom. WeWillWin🇬🇧🇺🇸
Post #811408 22nd Jan 2020 12:07am
timthepom
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
I have got the on my Defender...they are insanely good and highly recommended.
https://www.landroverdefendersecurity.com/...washer-jet
Post #813964 6th Feb 2020 8:48pm
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Hello if you don't mind can I bring this one back
On my 2.4 Puma my front water jet stopped working so I followed the instructions herein and replaced the jet
Thanks guys Thumbs Up
But still it doesn't work - despite the pump making a noise - no water coming out of the tube.
So do I have to replace the water bottle and two pumps that come with it ?
Also do I have to dismantle the heater air intake to do this ?
As some of you know I am a debutant at getting my hands dirty so all advice gratefully received Mr. Green
Post #827351 24th Apr 2020 12:20pm
landy andy
Does water come out from the pump. That is what you need to know. If no, you need a new pump, if yes, you’ve got a split/cut pipe somewhere. Probably the oneway valve.
Post #827353 24th Apr 2020 12:27pm
CharlieDonuts
So is the pump is on the back of the water bottle right ? Do you know the best way to get to it ? I'll go down a take a look after work.
Post #827368 24th Apr 2020 1:46pm
CharlieDonuts
Just in case some one else comes along.
I replaced the front water jet with a CNC billet one - nada
I replaced the pump (accessible by removing the headlamp) - rien
I checked for splits and leaks - nichts
Then I found 3/4 down the wing, a tiny little plastic non return valve inserted into the tubing, I removed it, throughly cleaned it with some solvent and a tooth pick. Thumbs Up I have never seen so much water spray onto my windscreen ever. Flipping brilliant it is now. Thumbs Up Thumbs Up Thumbs Up
So if you only have a dribble check this little valve first.
Post #829332 5th May 2020 8:41am
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Replaced my washer jet with the CSI Parts fan style one today.
Wasn’t a bad job thanks to the advice on here.
The new washer is so much better. Makes a huge difference and in my opinion is well worth £80.
Only annoyance with the CSI parts jet, was the new nut was 17mm (the old one was 13mm), so had to dig out my full socket set (which was hiding in the attic) and the deep 17mm socket was a really tight fit against the dash Very Happy
Other than that, really happy I did it! 2011 CSW XS 90
Post #885352 13th Feb 2021 8:10pm
DeCA
Belgium 2007 Defender 90 Puma 2.4 SW Barolo Black
Great Tip!
John Fair wrote:
Ref dash not having to come out in a puma- on mine I removed the center console (2 screws, pull to remove clips, remove wiring blocks), I then removed the metal bracket blocking the view of the back of the washer jet ( 8mm bolt, 4x plastic Christmas tree screw things with plugs) and simply tightened the washer jet mount with a 13mm deep socket after pulling pipe off the rear. Hopefully this helps someone. Realistically 15/20mins. Oh and a flashlight.
Post #1003266 7th Aug 2023 12:43pm
Stacey007
Hello
I've been off the forum for a while, in fact so much so hundreds and hundreds of new posts...
With the Defender being used less and less jumping in it and using the washer 'jets' you do think ooh they are cr@p...
I've put new bosh wipers on and tempted to use the CSI billet washer jet? I guess this is straightforward swap? I've had the head unit (double din) thing out so many times phafing with it and seen the bolt holding the jet on to bulkhead.
Has one one fitted a more powerful pump to the front system?
Thanks
Post #1014543 9th Nov 2023 3:26pm
geobloke
Hi Stacey. I know they are more expensive, but the Optimill washers and pump is absolutely excellent. Cannot fault it one little bit. It is one of those mods that should just be a standard mod like LED lights. Just my opinion I know, but that is how good I think they are.
Post #1014556 9th Nov 2023 5:25pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I cleaned out all the pipes, the jet and the tank. I removed the non-return valve from the pipe run. The standard system now works OK. Another good inexpensive mod I've seen is to fit two standard jets.
Post #1014676 10th Nov 2023 11:55am
Stacey007
Hi Steve
Is the none return valve bit easy to spot?
Thanks
Post #1014677 10th Nov 2023 11:58am
steveww
On my 2015 CSW there's two pipes that run from the washer tank passed the heater. There's a push fit connector, on mine one was straight through the other was a non return valve. The valve reduces the flow quite a lot. I also modified the wiper relay so that washing does not start wiping, this allows for plenty of water on the screen before manually activating the wipers.
I can get some photos later on today if required.
Post #1014679 10th Nov 2023 12:27pm
Screbble
Stacey007 wrote:
Hi Steve
Thanks
Yes just carefully pull/feel the pipe by the heater box under the bonnet.
I replaced mine for a couple of quid, expecting it not to make a difference (and I’d have to replace the nozzle) BUT it was night and day - blasts the windscreen now 👍
Obviously you can also remove it which others have done.
Post #1014742 10th Nov 2023 7:56pm
Page 4 of 5 <12345>
