Home > Puma (Tdci) > Puma Recall N706; Front axle case flange reinforcement brkts |
stick Member Since: 11 Mar 2018 Location: hants Posts: 6 |
Mine also cancelled today - supposed to be in tomorrow
7th Nov 2023 5:09pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
I just cleared it with SWMBO and got clearance to buy and install the brackets for safety's sake.
Unfortunately the local dealers here don't really care about the Legendary units anymore and just push the new ones. |
8th Nov 2023 1:32am |
Very Rural Member Since: 04 Jul 2023 Location: Shropshire Posts: 58 |
I've had exactly the same with mine, a call yesterday, -again with no ETA for the other bracket. |
6th Dec 2023 5:23pm |
So here I am again, having had the second booking for the bracket recall deferred, I have just got back from a JLR dealer in Worcester, who has also declined to fit the brackets.
It seems as though my long-haul chassis replacement has struck again! (see my previous posts regarding the replacement galvanised chassis... Having today done a 112 mile round trip, paid for lunch out, six hours later I am back at square one. Apparently, the N706 recall brackets could not be fitted as the bolts that hold them that go through the radius arms. have been put in with the bolts facing the wrong direction. As I don't have another Defender to hand to look at, I'm unsure which way round they should be. For the dealer to fit the brackets, they said that the bolts would have to come out & be reversed. That will take more time than the allotted 12 minutes that JLR allow. I was given the option of paying for that, at £110, but they couldn't do it today, I would need to bring it back. (Another 112 miles & a further day gone). I asked why they couldn't do it whilst the vehicle was there, & apart from the time-scale, they are not allowed to do anything that requires more work or parts, under the recall warranty. It would be a separate job: 1: Reverse the bolts, Charge £110. 2:new job, remove nuts & fit brackets... Not at the same time? Needless to say I'm not going back there, so failure from a second dealer. The only option open to me appears to be for me to reverse the bolts, then try & find a third dealer to do the recall. This is the only way I can see forward that will get the required JLR outstanding recall cleared. Bearing in mind that I originally purchased the 110 from the Worcester dealer, you would have thought that they might have been more helpful! So please can someone post a picture of the front axle, showing which way the nuts should be orientated, as it would appear that when the chassis was replaced the bolts were put in the wrong way round. Thanks, David. |
19th Jan 2024 5:19pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1862 |
Sorry, I feel your pain. This is how my nearside looks, hope it helps. Fitted myself and I am pretty hopeless
Click image to enlarge Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
19th Jan 2024 5:33pm |
Thanks, that's how my near-side bolt is orientated...
So is the other side the reverse, i.e. the bolt head is on the inside, & the threaded end towards the wheel? |
19th Jan 2024 5:39pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1786 |
Fell out with that dealer in 2000 when they were in Droitwich & they damaged my wifes brand new Freelander and didn't give a toss - staff will have changed attitude hasn't.
Visited them on the new site to look at a new Freelander 2 in 2007 - they said they were on such tight margins they wouldn't throw in a teddy bear for my 10 year old daughter, they couldn't believe that I walked away! After all of the messing about you've had to do, have you considered either a new case or a second hand reinforced one? |
19th Jan 2024 5:45pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3422 |
Remember that there are 2 bolts per side, one infront and one behind the axle. All 4 bolts should be with the heads on the inside, and nuts towards the wheels. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
19th Jan 2024 6:05pm |
A picture of the other side anyone?It would seem maybe only one bolt on mine is miss-orientated?
David. |
19th Jan 2024 6:08pm |
Driver side.
Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
19th Jan 2024 6:18pm |
Brilliant, thanks very much!
My question to Listers in Droitwich now is, why didn't they say it was only the one bolt that was incorrectly orientated?!! I've wasted a whole day again, just because some incompetent engineer can't be bothered to reverse a bolt, & wants to make me book a new job, & charge £110.for the privilege?!! I shall get back to them... |
19th Jan 2024 6:43pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
Unbelievable!!! Puma 110" SW
19th Jan 2024 6:50pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Not an engineer 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th Jan 2024 8:01pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1428 |
And all of this is for a safety critical defect that could kill somebody in the wrong circumstances.
It just goes to show how concerned about the problem they are, both the dealer and JLR. |
19th Jan 2024 10:07pm |
