Home > Td5 > Td5 110 camper set up
Page 7 of 8 <12345678>
Screbble
You’re getting there and doing a grand job 👍
Post #1013006 28th Oct 2023 5:27pm
Register
Thanks for the kind words. I fear your eyesight maybe as bad as my measurements 😂.
A bit more progress, but I now need to plan the storage around some kit I already have and figure out sleeping arrangements.
What’s the view on diesel heater capacity 2 or 8Kw?
Also separate fuel tank or bridge into the existing fuel line? Before or after the pump?
Where best for the exhaust?
Is it ok to keep air intake internal?
Thanks. Everything's a hammer.
Post #1013305 31st Oct 2023 7:48am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
2kw is the normal heater size for a defender as you can run it up to full speed to keep from sooting, others have fitted the 5kw and found that more than ample. We have had 2kw heaters and have found that enough for us and often run them overnight on low to keep the chill off in winter.
The 5 and 8 kw heaters are much bigger than the 2kw; which fits nicely under the seats or in the under cubby box units.
Power and fuel use are not too much of an issue with any of these units, however you must be carful not to block the hot air outlet as this may melt or damage clothing and jackets (... ask me how I know !! Whistle )
The price of them has come right down now so well worth the upgrade for anyone thinking of fitting one.
Thumbs Up
Fuel is easy to use the main filler hose with a scavenger line that works very well and does not disrupt the fuel system of the vehicle, plus will not drain the tank if used for a long time.
Exhaust should aim to the opposite side of any awning you may fit and above the lower point of the chassis to prevent fouling when off road.
Air intake for the heater should be out side of the vehicle pointing to the opposite side of the exhaust.
Fuel pump mid way between the tank and heater on the chassis is best with a slight upward angle ..
hope that helps
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #1013334 31st Oct 2023 11:35am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
For fuel TD5 in tank pump is prepared for connection. Just ad "needle" in the prepared port. It was designed for fuel burning heater. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1013423 31st Oct 2023 7:59pm
Register
Wyvern - Thanks for all the detail. I was tempted by the larger capacity as they're cheaper, but have now gone with 2Kw.
I'm not altogether clear what you mean by
'Fuel is easy to use the main filler hose with a scavenger line that works very well and does not disrupt the fuel system of the vehicle, plus will not drain the tank if used for a long time.'
Do you mean just push the skinny heater fuel line into the side of the filler pipe and into the tank?
MadTom - I found this image. Do you mean connect/push the heater line into no.1?
Thanks both. Everything's a hammer.
Post #1013487 1st Nov 2023 10:16am
wyvern
one of these to fit in the fuel filler line ... simple job and works very well ..
https://www.butlertechnik.com/eberspacher-...252a-p1291 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #1013492 1st Nov 2023 10:41am
Register
Thanks, that all makes sense now.
I'll probably save the cash and bridge into the fuel pump as I already have an access panel.
I'll make a plan when the heater arrives.
Or maybe this....
....with credit to tatra805 Everything's a hammer.
Post #1013572 1st Nov 2023 6:26pm
MadTom
Yes, the no. 1 is the right connestion port. I made it to our Discovery 2 long time ago, and last year to Defender 130. Discovery 2 has original hatch over the pump, with 130 it was with removed tub. Just set the fuel needle in tank to correct length, not too deep. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1013602 2nd Nov 2023 6:54am
Register
Thanks for clarifying that.
All made sense once i removed the ‘access hatch’.
Is there an appropriate length of fuel line to insert?
So far there appears to be no limit and I assume it’s just curling up in the bottom of the tank.
Really ought to have taken a look underneath whilst planning the heater location.
There’s a rather inconsiderate 50 x 50mm box section right where I don’t need it.
Thanks Everything's a hammer.
Post #1014135 6th Nov 2023 7:17pm
MadTom
I was usin rigid needle in tank (copper or stainless tube), not just flexible pipe. Wegasto has some good manuals on web. Function of heaters is the same, differences are in connectors or control panels. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1014212 7th Nov 2023 12:43pm
Register
MadTom - thanks for the advice. I’ve abandoned the flexi fuel pipe and used a metal piece as you suggested. I’ve left it about 3cm from the bottom of the tank, but no idea what that means in terms of fuel or driving range.
Left the heater for a bit to work on what’s looking increasingly like a sauna.
Rock ‘n’ roll bed works surprisingly well and cooker, sink, fridge now mocked up.
Feeling very pleased until I tried to close the rear door. 😩
What’s the view on used water? Direct to ground or catch tank?
Post #1015670 19th Nov 2023 5:50pm
Register
I’ve been rather busy on other things but departure date is rather looming.
A bit of an update on hole drilling day.
Apparently it helps ventilate the mattress and offset the additional weight or neither. 😂😂
Also solid evidence of measure once, cut forever to fix the f up. 🤮
Post #1020363 7th Jan 2024 10:47am
Register
Now with first coat of vanish. Front left still wet.
And then the wheels and tyres. Certainly need to get rid of the blue lettering and hopefully black centre caps will sober up the rather bling colour 😕.
Post #1020521 8th Jan 2024 12:56pm
TexasRover
Is that the inside picture of your Hummer, or is your lens making that look deceptively large?
Good progress. You know one day you actually need to go and use it
Post #1020527 8th Jan 2024 1:40pm
Register
Vintage iphone 8 - the camera never lies.
Driving France and Spain then crossing to Morocco on 4th Feb, hence the burst of activity.
And its just started snowing. Everything's a hammer.
Post #1020529 8th Jan 2024 2:03pm
