Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
sullivan1337 Member Since: 24 Oct 2023 Location: Pittsburgh Posts: 8 |
Nevermind Patrick is a wizard and literally replied in 5 minutes to my email.
Thank you!! |
26th Oct 2023 5:24pm |
Pauljm Member Since: 25 Oct 2023 Location: Sydney Posts: 8 |
This is all mine has * EUCD-150 Air Quality Sensor With Air Quality Sensor |
28th Oct 2023 3:48am |
malibu Member Since: 11 Sep 2023 Location: Melbourne Posts: 51 |
Mine also has EUCD-150 Air Quality Sensor
With Air Quality Sensor but does not have the screen. So i think there must be another CCF setting that turns on the screem. |
28th Oct 2023 6:07am |
@Adamalli or anyone else, what CCF edits does this require? From what I can see this isn't a hardware change required? |
29th Oct 2023 10:11pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
This can be done with configurable TR, the following settings should sort it
- Configurable TR MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
29th Oct 2023 10:51pm |
Adding more info here!
To make the Configurable Terrain Response (Config TR mode) selectable from the rotary knob and not just the touch screen: Along with the initial: MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout I was able to successfully select with the rotary after I changed the following: MultiCAN-797 Ter CT Select In FCPB - Changed to > "Rotary used for selection within touch screen" Cheers! 24MY Defender 110 P400 X-Dynamic SE, Pangea Green. |
31st Oct 2023 3:56am |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 238 |
If the gap tool can eventually read the DADC Driver Assistance Domain Controller and clear the DTC codes then I think the gap tool will be able to do activate ACC, ATPC , TR2 Auto, Park Assist, wheel size change etc. I believe Patrick at GAP is working on a solution to this MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
6th Nov 2023 7:02am |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 136 |
Yes he is, I emailed him enquiring re the GAP tool for my MY23.5 and he said to hold off ordering until they sort that out.
6th Nov 2023 8:15am |
These are the CCF file changes I made to make ATPC and Auto TR2 work, I also had to clear the DTC in the DADC driver Assistance Domain Controller which you cannot yet do with GAP tool but hopefully soon
EUCD-129 Terrain Response Fitment ‘With Terrain Response’ changed to ‘Auto Terrain Response/JDO, Dynamic’ MultiCAN-476 ATPC ‘HDC only’ changed to ‘HDC and LSPC’ MultiCAN-562 DynamicProgMode ‘Available for selection without timeout’ changed to ‘Available for selection with timeout’ MultiCAN-682 DynamicLiteMode ‘Available for selection without timeout’ changed to ‘Available for selection with timeout’ MultiCAN-696 ATCM Auto TR Mode Switch ‘Auto Terrain Response Mode selection switch not fitted’ changed to ‘Auto Terrain Response Mode selection switch fitted’ MultiCAN-754 Auto TR Prog Mode ‘Not fitted’ changed to ‘Fitted’ MultiCAN-778 ATPC Select In FCPB ‘Control interface not available in FCPB’ changed to ‘Available as shared purpose button’ MultiCAN-778 Ter Auto Select In FCPB ‘Control interface not available in FCPB’ changed to ‘Rotary used for selection within touch screen’ MultiCAN-789 Drive Mode Order ‘All Terain Vehicle Standard Order’ changed to ‘AlI Terrain Vehicle Including Auto Order’ MultiCAN-797 Ter CT Select In FCPB ‘Control interface not available in FCPB’ changed to ‘Rotary used for selection within touch screen’ MultiCAN-798 Ter CP Select In FCPB ‘Control interface not available in FCPB’ changed to ‘Rotary used for selection within touch screen’ MultiCAN-853 ATPC Button Type ‘Not fitted’ changed to ‘Hard Button Fitted’ MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
6th Nov 2023 10:52am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
Ive just had a look at my build sheet and it turns out I do have an air quality sensor fitted. Where do I find this screen please? I cant seem to find it. Or does the display need to be "turned on"? If yes how do I do that please? Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
6th Nov 2023 11:05am |
Could possibly be this?
MultiCAN-510 AirIonizer Front Air Ionizer fitted EUCD-150 Air Quality Sensor With Air Quality Sensor MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
6th Nov 2023 11:54am |
Thank you I will try that. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
6th Nov 2023 12:44pm |
StromC Member Since: 30 Jan 2023 Location: Rockville Posts: 13 |
Bringing this topic up again...
Has anyone had any luck on finding settings to disable the fog lights coming on with the indicator lights? |
7th Nov 2023 4:18pm |
