Home > In Car Electronics > Central Locking Fuse? 110 Puma 2008
Rossco123
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Caledonian Blue
Hi - first time posting so please be gentle. I have a Defender 110 XS Puma 2008 Right Hand Drive. Upon purchasing I reaslised the Central locking wasnt working. I took the door panels off (all doors and rear door) and found broken wires at the pillar. I repaired this and still no joy. I will get a multimeter later today to see if there is a signal - however I wanted to check if there is a fuse I should check?
I started pulling fuses from under the drivers seat (to check) and this messed up my alarm fob (now sorted!) - so hesitant to pull any more without knowing what I am touching. I have the fuse diagram but there are no obvious central locking fuses.
Are there any central locking fuses on the 10AS box or obvious ones under the steering wheel?
All help appreciated
Post #1011203 14th Oct 2023 1:02pm
Rossco123
Small update - I tried the altimeter and there is no signal going to the doors (I tried on the rear door and the offside rear door whilst pressing the fob) - does this indicate a fuse or 10as issue? - no doors are being locked/unlocked when I press the fob and I have checked all the wiring in all the rubber gators and door panels. Thanks!
Post #1011263 15th Oct 2023 8:38am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi, welcome,
there are no fuses between AS10/ALM and door locking motors.
Given that none of your doors work, I'd check the voltage at the AS10 connector, although it may be fiddly to get there.
Also maybe the previous owner had CDL deactivated in software?
Post #1011293 15th Oct 2023 11:18am
Rossco123
thanks Mac - i was wondering if the previous owner had deactivated - can you reactivate via an OBD scanner? if so any recommendations (on a resonably priced one) would be appreciated.
Interestingly in addition to the broken wires the passenger side central locking actuator was disconnected so am wondering if someone was trying to previously fix it and gave up. I have connected this back up and inspected all the other wires so it could be that somone diactivated via software.
Thanks again - really appreciate the pointers
Post #1011295 15th Oct 2023 11:53am
Ianh
A Nanocom can do it, and it’s a great diagnostic tool for the Puma 2.4, but will set you back about £380 via group buy on here.
There may be a member close by with one that would be happy help out.
Ps. Worth noting here are two versions of the 10AS, one with central door locking relays, one without. Now your XS should have the central locking from factory, however if the unit went faulty it may have been replaced with one without CDL.
Have a read of this for details https://www.technozen-electronics.co.uk/la...-services/
Post #1011296 15th Oct 2023 12:01pm
Martin
Site Admin
Fuse 6 and Fuse 7 is where to look.
Could be a few things - blown fuse, broken wiring, replaced 10AS unit without central locking functionality, disabled central locking, faulty 10AS.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011317 15th Oct 2023 3:59pm
macfrank
Fuse 6 and 7?
Post #1011340 15th Oct 2023 8:18pm
Martin
Site Admin
Fuse 6 and Fuse 7 are the 12V permanent supplies to the 10AS.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011344 15th Oct 2023 8:31pm
Martin
Site Admin
They are in the underseat fuse box  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011345 15th Oct 2023 8:34pm
macfrank
ah , ok, I thought he mentioned the alarm was working? But wont do any harm to check them anyway Smile
Post #1011358 16th Oct 2023 7:10am
Rossco123
Thanks all - i have checked all fuses under the seat and these were all ok. I will check the 10as CL outputs and see where this gets me. Final check would be to see if its been deactivated (or the box was replaced with one that didnt have it)....
Thanks again... much appreciated
Post #1011367 16th Oct 2023 8:06am
Martin
Site Admin
Check the orange and pink pair coming out of the 10AS unit - on the green connector they are the pair next to each other in pins 2 and 3.
Obviously this needs to be done with the connector still fitted! You should be able to flick up the flap and get access to the back of the terminals.
With your multimeter in volts mode, with "COM"/GND/black probe to pink and "V"/red probe to orange, you should get a positive voltage pulse when you unlock, and a negative reading when you lock.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011371 16th Oct 2023 8:57am
Martin
Site Admin
Also get the part number off the sticker on the 10AS, we should be able to tell you if it's the central locking version or not.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011373 16th Oct 2023 8:59am
Rossco123
So helpful - thanks.... I will check tonight after work and keep you all posted. thanks
Post #1011414 16th Oct 2023 11:58am
Rossco123
Hi Martin - only just got round to looking this morning (work got in the way!) - i couldnt quite open the 10AS box (despite taking numerous screws out of the dashboard) - as such have not been able to test. the sticker states: YWC500660, 10AS-433MHZ, 52010501F, 1439140. It also has the Pink and Orange wires you mention (in pins 2 & 3). Do you know if this box supports CL?
Any other tips on how to get access? I took the speaker out but couldnt lift the lid on the 10AS box.
Thanks...
Post #1012011 21st Oct 2023 12:23pm
