![]() | Home > In Car Electronics > Central Locking Fuse? 110 Puma 2008 |
Rossco123 Member Since: 14 Oct 2023 Location: Gloucestershire Posts: 11 ![]() ![]() ![]() |
Small update - I tried the altimeter and there is no signal going to the doors (I tried on the rear door and the offside rear door whilst pressing the fob) - does this indicate a fuse or 10as issue? - no doors are being locked/unlocked when I press the fob and I have checked all the wiring in all the rubber gators and door panels. Thanks!
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
Hi, welcome,
there are no fuses between AS10/ALM and door locking motors. Given that none of your doors work, I'd check the voltage at the AS10 connector, although it may be fiddly to get there. Also maybe the previous owner had CDL deactivated in software? ![]() Click image to enlarge ![]() |
thanks Mac - i was wondering if the previous owner had deactivated - can you reactivate via an OBD scanner? if so any recommendations (on a resonably priced one) would be appreciated.
Interestingly in addition to the broken wires the passenger side central locking actuator was disconnected so am wondering if someone was trying to previously fix it and gave up. I have connected this back up and inspected all the other wires so it could be that somone diactivated via software. Thanks again - really appreciate the pointers |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2272 ![]() ![]() |
A Nanocom can do it, and it’s a great diagnostic tool for the Puma 2.4, but will set you back about £380 via group buy on here.
There may be a member close by with one that would be happy help out. Ps. Worth noting here are two versions of the 10AS, one with central door locking relays, one without. Now your XS should have the central locking from factory, however if the unit went faulty it may have been replaced with one without CDL. Have a read of this for details https://www.technozen-electronics.co.uk/la...-services/ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Fuse 6 and Fuse 7 is where to look.
Could be a few things - blown fuse, broken wiring, replaced 10AS unit without central locking functionality, disabled central locking, faulty 10AS. ![]() ![]() |
Fuse 6 and 7?
Fuse 6 and Fuse 7 are the 12V permanent supplies to the 10AS.
They are in the underseat fuse box
ah , ok, I thought he mentioned the alarm was working? But wont do any harm to check them anyway
Thanks all - i have checked all fuses under the seat and these were all ok. I will check the 10as CL outputs and see where this gets me. Final check would be to see if its been deactivated (or the box was replaced with one that didnt have it)....
Thanks again... much appreciated |
Check the orange and pink pair coming out of the 10AS unit - on the green connector they are the pair next to each other in pins 2 and 3.
![]() Click image to enlarge Obviously this needs to be done with the connector still fitted! You should be able to flick up the flap and get access to the back of the terminals. With your multimeter in volts mode, with "COM"/GND/black probe to pink and "V"/red probe to orange, you should get a positive voltage pulse when you unlock, and a negative reading when you lock. ![]() ![]() |
Also get the part number off the sticker on the 10AS, we should be able to tell you if it's the central locking version or not.
So helpful - thanks.... I will check tonight after work and keep you all posted. thanks
Hi Martin - only just got round to looking this morning (work got in the way!) - i couldnt quite open the 10AS box (despite taking numerous screws out of the dashboard) - as such have not been able to test. the sticker states: YWC500660, 10AS-433MHZ, 52010501F, 1439140. It also has the Pink and Orange wires you mention (in pins 2 & 3). Do you know if this box supports CL? Any other tips on how to get access? I took the speaker out but couldnt lift the lid on the 10AS box. Thanks... |
