Home > My Defender > Defender 90 puma low milage but was used on a farm.
Page 1 of 4 1234>
Landy addict
Thought I would share my project on here I have been working on it so about half way through now, but I have some photos from the beginning. It is a 2009 90 with 46k & FSH it belonged to a farmer from new so probably spent most its life off road & covered in dung & that stuff is like acid to steel & Alloy. Photo below is from a couple of year ago when I first got it I didn't realise how bad it was going to be (I bet some of you are laughing right now at that comment) & I should have known better as I have had defenders before.
Below photo is when I finished the shed land rover is sitting more or less in same place as photo above
during an inspection I saw the dreaded rear crossmember rot further investigation was frustrating as it turned out there was more in other parts of the chassis so started stripping it down
Post #1005519 26th Aug 2023 8:04pm
Welshsurferdude
Wales
love these project and great shed!
Im currently awaiting planning to build a similar sized shed for my back garden! 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #1005523 26th Aug 2023 8:24pm
Moo
Ukraine
I now have serious shed envy! Big Cry Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1005527 26th Aug 2023 9:14pm
Procta
Nice fords!! love the escort!!!
me and my dad would kill for a shed like that, a couple of drive on ramps in there, racking for spare parts and oils. A proper be a proper work shop. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1005539 27th Aug 2023 1:13am
Landy addict
Thanks for the comments I have only just got the building warrant for the shed there was a lot of restrictions as to what I could put in, now I can start fitting it out. First thing will be a 2 post ramp as my knees are struggling kneeling or laying on the floor to work on things (that's what getting old does Crying or Very sad ). I joined it onto my garage & put an access door through so most of my stuff is still in there at the moment. I have got to say respect to all you guys that does this kind of project in a single garage or even worse on the driveway, I am still tripping over things with all this space.
Post #1005549 27th Aug 2023 8:58am
TexasRover
Nice shed! Oh yeah and also nice Landrover.
Must be nice working on a Landrover in SUCH A NICE SHED!
Some people have it all..
Post #1005580 27th Aug 2023 4:35pm
Landy addict
When I started cleaning the axles I found that they were also rotten.
Someone had sealed the leak with filler / liquid metal or something had noticed it seeping just after I got it but thought it was just a seal
Post #1005738 29th Aug 2023 12:14pm
geobloke
Shocked Shocked Blimey are they rusted or what Rolling with laughter
Post #1005741 29th Aug 2023 12:18pm
Landy addict
New chassis & some other bits I got for the rebuild
Post #1005746 29th Aug 2023 1:17pm
Jim1988
Wow this is going to be a great one to follow. PS nice shed 😬, wise investment 👌. Thanks Jim.
Post #1005784 29th Aug 2023 5:51pm
Landy addict
Starting the prep for the re-build, first I power washed & de-greased the galvanisation next coated it all in T-wash ready for paint. I didn't want the silver look for the chassis I also went for the Marsland chassis because it is basically identical to the original LR one also has chassis number in correct place.
Post #1005793 29th Aug 2023 6:31pm
Landy addict
some other bits for the build
all the wheel bearings front & back
Springs from Alive tuning along with the new Alive / Bilstein shocks (these are meant to be softer than standard Bilstein but harder that Fox)
bush kit
Post #1005801 29th Aug 2023 6:53pm
NickMc
That’s going to be lovely when it’s done.
Did you have the axle casing galvanised yourself? I’m contemplating doing mine. Where’d you buy the galvanised brake disc shields from?
Post #1005811 29th Aug 2023 7:08pm
Landy addict
I got the disc shields from YRM this is the link https://yrmit.co.uk/product/hdg-rear-mudsh...er-d1-rrc/ my both axles where completely shot so had to replace them got them from KD-LR same place I got the chassis Karol & Gemma there couldn't be more helpful.
Post #1005819 29th Aug 2023 8:02pm
Landy addict
First coated items with a coat of epoxy primer grey
Then 2x coats epoxy chassis black
Post #1005877 30th Aug 2023 9:06am
Page 1 of 4 1234>
