Home > Maintenance & Modifications > Heavy duty or single piece half shafts? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
P38 is a rover diff. The non rover diff is the Salisbury diff fitted to early 110’s
20th Jan 2022 12:34pm |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 |
I have a 2009 Defender Puma 90 CSW. I Fitted Disco 1 solid drive shafts on the back. Got rid of 50% of the knock on drive. Just fitted the new adjustable A Frame Ball Joint and the knock is now gone. For now. For normal driving I would say Disco 1 rear solid shafts all the way.
20th Jan 2022 5:23pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 842 |
Does anyone know if the 1 piece shafts (Part Numbers FTC3270 & FTC3271) fit a 110 Puma? 2008 2.4 110 Utility Station Wagon XS.
17th Jul 2022 8:38am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17478 |
Most web listings say that they do.
17th Jul 2022 10:42am |
Brilliant
Thank you! 2008 2.4 110 Utility Station Wagon XS. |
17th Jul 2022 11:12am |
Nice update. I’ve managed to hunt down a pair of genuine LR HD single piece driveshafts going at not too unreasonable price.
Looking forward to getting rid of the 2 piece clunkers. 2008 2.4 110 Utility Station Wagon XS. |
4th Apr 2023 3:49pm |
nicholas2012 Member Since: 28 Jun 2012 Location: lanarkshire Posts: 193 |
https://www.ebay.co.uk/itm/265726526460?mk...media=COPY
Would these be the britpart one piece rear half shafts to buy? The drive flanges on my defender have had a big amount of slack for years always noticeable when pulling away, had always been expecting splines to start slipping, have done 130K miles so have done okay and could do with replacing them when sorting a few other things... £130 would be a decent price? |
30th Jul 2023 9:17am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
I brought a good pair of disco single piece shafts from a breaker for £20, they have been on the car for several years with no issues (shafts are smaller diameter but who knows what material), I tow a caravan and it is lightly tuned no issues so far. DEFENDER 90 TDCI XS,
31st Jul 2023 6:56am |
Yes I had a few tdi discovery's before the defender funnily enough I broke my last one for spare parts, Listed the back axle with about £50 starting bid it had recent disc/pads and calipers at the time. Only had one bid so somebody got a absolute bargain there...
About a year into defender ownership the rear diff pin bolt sheared and the discovery one would've fitted that, upgraded it to a ashcroft atb Even with the discovery shafts being a slightly smaller diameter I'd assume they'd be stronger than the two piece parts probably need to be do some big burnouts or extreme off roading to snap or twist them |
31st Jul 2023 7:32am |
Looking for a opinion ordered these half shafts from maltings 4x4 (in link i posted above) and they've sent two different brands the longer one has a thick end flange and thicker shaft whereas the short one has a thinner shaft and more curved less beefy flange end
I think ones a britpart HD shaft and the other is a allmake 4x4 discovery 1 type replacemen, sure it would do the job but contemplating contacting them to see if it can be exchanged for the heavy duty type which is what I expected as a pair Do you think I'm being fussy? I'll upload some photos to show difference between shafts... |
14th Sep 2023 9:55pm |
Halfshafts
14th Sep 2023 9:58pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
14th Sep 2023 9:59pm |
14th Sep 2023 10:43pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1632 |
I would call them mistakes happen, I’ve always found them very good to deal with.
14th Sep 2023 10:50pm |
