![]() | Home > Td5 > Air con dash removal |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 809 ![]() ![]() ![]() |
I'd be interested to know this too
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3508 ![]() ![]() ![]() |
link to an old thread https://www.defender2.net/forum/topic46527.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
There are the 2 screws either side of the AC unit and the big one in the centre. That is it.
It is best to remove the centre fuse box cover first. For extra space remove the gear stick. Lower the AC unit slowly as you will have to unplug it from the main loom in the fuse box. ![]() |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 901 ![]() ![]() ![]() |
Thanks for the help guys.
I was removing it so that I could get to the 10AS unit behind the front drivers side lower speaker. Luckily I didn’t disconnect it from the A/C system as to get to the screws of the 10AS you need hands the size of a 3 year olds. If you ever need to remove the 10AS unit the easy way is to undo the 4 screws holding the front of the instrument binnacle on and it sits on the bulkhead just behind. You will need a long shaft or flexible shaft Phillips screw driver and once the binnacle face has been moved to one side it really is a 5 minute job….. Jim |
Indeed, there is nothing behind the lower dash, except the wiper motor on the passenger side. But that part of the lower dash is removeable on its own. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Dinnu, yes the small panel on the lower passenger side to make access easier for the wiper motor. I guess that the folk who positioned the 10AS module assumed that it would never have to be repaired or replaced?
Jim |
Blimey...theres not much holding this in really
Here’s the 10AS unit easily visible after removing the instrument binnacle.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Jim |
