![]() | Home > V8 > 3UZ-FE conversion |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 136 ![]() ![]() ![]() |
Hi Linds, I don't know why the main shaft moved forwards other than there was no reason why it shouldn't. The gearbox guy who looked at it immediately said there was something wrong with the set up. All conversions he's seen had to have a bolt through which was how I cured it. It may have stayed where it was without the bolt, once he'd tightened it up with BMW flange, but it wasn't worth the risk when there was a relatively simple solution. I sent a message to Shabs at synchro to ask if he'd had a problem but got no reply so I assume it isn't a problem till it becomes one
![]() ![]() 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
![]() Click image to enlarge Zero progress on transfer gears ( Shoulder still knackered) But I ditched the K+N filter and reinstated the puma airbox. This seemed to make the exhaust note a bit quieter, not sure why, I also put the engine cover on for a more factory look ![]() 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
Looks quite smart there Tim, what did you do with the feed from the expansion tank, wehre does it go? 4.0 V8 Defender 90
My Instagram |
Hey Luke I tee'd into bottom hose with bits from puma cooling system which was needlessly complicated
Okay Dokay I'll be doing the same then. Cheers Tim 4.0 V8 Defender 90
My Instagram |
![]() Click image to enlarge Back in workshop for more surgery ![]() Click image to enlarge Transfer box out as too low geared. I was going to tackle this myself but I just don't have enough kit ( Bench press) or confidence and shoulder is still very painfull (awaiting an op) ![]() ![]() Click image to enlarge I'm now going to return the box and gear set back to Ashcroft transmissions and let them deal with it. While they're in there I'm getting an ATB fitted. Citroen 2CV. (Written off) 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
Interestingly when I removed transfer box the pin I put in the BMW output shaft converter was snapped in two places
It's been a year now and still an absolute joy to drive.
![]() Click image to enlarge Changed the air inlet set up from this ![]() Click image to enlarge to this. The difference was amazing. Tickover went from 1100rpm to 800rpm, throttle response, power and sound all improved. Also removed the centre box from the exhaust for a throatier sound which makes me happy ![]() ![]() Click image to enlarge Also cut this hole in the air intake and put in a bit of guttering to divert and hopefully force a bit more air into engine. All little adjustments but very satisfying improvements. Citroen 2CV. (Written off) 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
Sounds like youre coming to the end of the build then Tim you've done a good job.
How do you find the ATB? I love them. odd regarding the output shaft and issues with teh change. Do hope I don't encounter the same. Need an update on that noise btw, can't be having too loud now ![]() My Instagram |
Thanks Luke
![]() ![]() Ive not really noticed a difference with the ATB but I haven't been off road or had snow yet so time will tell ![]() https://youtube.com/shorts/tI6vG-hVWOc?feature=share New sound video. ![]() ![]() 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
Easier in a 90 but trying kicking the front inside wheel up round a bend its wicked
![]() Youtube post sounds about right mate, love it ![]() My Instagram |
Where have you been Tim - and how's the shoulder?
What do you think to the 1.100 ratio in the transfer box? I'm considering now lengthening mine down to a 1.003 or even 0.9 so I can hit 60MPH at the top of 2nd gear.. Need some first hand advice while still accounting for the extra mass of your 110... Cheers 4.0 V8 Defender 90 My Instagram |
Hey Luke sorry only just seen this! I used to get notifications but they've stopped for some reason
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Click image to enlarge Citroen 2CV. (Written off) 66 Ford Mustang (Sold) Land Rover Defender 110 Hard top 300 tdi (Sold and subsequently written off) And a few BMW's before seeing the light |
I bet its quite smooth travelling at speed now with a more balanced engine, not that the pumas would rattle. However, for me thats one of the many improvements. I may have to go to a 1.1 centre diff ratio also as its a tad short at the moment but other than that I cannot complain at all about my Gs6/ M57 box.
Noise wise I'm regretful of that fact that I didn't down hat you did and install cats on the down pipes, I need the volume reducing quite a lot ![]() Of course, add me. 4.0 V8 Defender 90 My Instagram |
