Home > Technical > Power loss in hot weather?
Page 1 of 7 1234567>
ZeDefender
Quick Puma question:
Normally, I can get up to 140+ Kmh (speed unlimited) consistently, albeit slowly. However, it's 30+ degrees today and driving home I couldn't get above 130. Seems to be running okay but just had no oomph Sad
Could this just be due to the heat and an insufficient intercooler or might something more sinister be afoot?
I've never had a chance to "test" the intercooling before so I don't know how sensitive it is to heat...
Matt Tell someone you love them today because life is short.
Post #144493 11th May 2012 2:46pm
MK
Probably intercooler and head temp sensor doing the job.
JMHO Defender is not designed to run as such speeds. Puma 110" SW
Post #144497 11th May 2012 3:17pm
ZeDefender
Cheers - you're right about the speed of course, but surely 138 Kmh ("official" limited speed) should be possible, even at 30 degrees Rolling Eyes
What's the head temp sensor? Tell someone you love them today because life is short.
Post #144502 11th May 2012 3:36pm
30C - never have that problem in the UK Rolling with laughter
Post #144503 11th May 2012 3:43pm
ZeDefender
... not to mention the speed issue Wink Tell someone you love them today because life is short.
Post #144505 11th May 2012 3:47pm
MK
Temp sensor. Probably you went over 108°C. DO you have a remap? Puma 110" SW
Post #144507 11th May 2012 3:51pm
ZeDefender
The remap wasn't loaded. The temperature gauge was normal. Guess I should look for an error code? Tell someone you love them today because life is short.
Post #144509 11th May 2012 3:56pm
MK
The temp gauge would not move at such temp. Between 82-110C or so, the thing stays at the same level. Not sure about the error. Worth finding it out. Thumbs Up Puma 110" SW
Post #144510 11th May 2012 3:59pm
ZeDefender
Sad 3 fault codes including P0100 - MAF Circuit malfunction Sad
I will reset it and see if it comes back...
Big Cry Tell someone you love them today because life is short.
Post #144514 11th May 2012 4:20pm
Eduardo
Other more!
I have the same issue in mine (30+ dregrees, long trips at 120-130 KPH).
The car lose power (reduce the speed) and after few seconds recover again the power.
As Mack said, appears to be a protection fault due a temperature increase that is not noticeable in the temp gauge.
As a hint before to think in change the intercooler: See if something restrict the flow in the radiator (mud, etc) or if the fan have been blocked.
Cheers Eduardo
Post #144516 11th May 2012 4:29pm
ZeDefender
Cheers Eduardo - glad I'm not the only one with this problem (but sorry for you...)
Nothing blocking the rad but I've cleared the fault codes and I'm about to hammer the motorway as fast as I can for 1/2 hour or so - I'll read the codes again when I get back... Tell someone you love them today because life is short.
Post #144524 11th May 2012 4:57pm
Lorryman100
Check that the air filter isn't clogged/dirty. Also diesels prefer cold dense air rather than warm air which is less dense. A bigger intercooler will help if you are in warm climes. Thumbs Up
P0100 Mass or Volume Air Flow "A" Circuit is a common untested DTC which comes and goes constantly.
Brian.
Post #144536 11th May 2012 6:24pm
ZeDefender
I know you're right... cleared the codes and drove like hell (well, slower than usual of course) for half an hour - P0100 code didn't come back, only the "usual" EGR P0404 Rolling Eyes
I also don't think it's just temperature - same power loss even when the engine had cooled down a lot...
About to check the air filter now.
One interesting thing though - after switching off for 5 minutes and restarting, the engine roared like hell (deep and throaty) for a few seconds as I pulled away Shocked Question Shocked
Any ideas? Tell someone you love them today because life is short.
Post #144539 11th May 2012 6:41pm
Tim_NZ
Australia
Sticking EGR?
Post #144585 12th May 2012 1:05am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
ZeDefender i bet the roaring is your viscous fan
mine does the same when hot as the temp rises under the hood when you stop and before the real cooling down starts.
Goes away within a couple of secs as the fan cools the coupling.
easy to check by the amount of dust it blows under the engine when revving it
edit: this can also explain your roaring sound at speed as mentioned in your other thread, if the engine compartment gets too hot the coupling will engage the fan.
Smile
Post #144756 13th May 2012 4:58pm
