Home > Technical > Power loss in hot weather? |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
I think the only people who can answer this would be the tuners?
I know the map files are quite large on the Puma (well, larger than the Td5), so I'd guess that most of this data would contain the programming to cause this fault under a certain condition. I'd presume that this would be able to be adjusted by a tuner, but at what risk to the vehicle? |
27th Jul 2012 9:31am |
Normally the remap write only a part of the sw like 3D fuelling, turbo, advance, ...... surfaces, not the whole sw like firmware for the processors, algorithms, .......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Jul 2012 10:29am |
i don't think they even go that deep TBH. |
27th Jul 2012 10:33am |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
I'll ask when I go there next - always worried I'll sound stupid though Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
27th Jul 2012 11:31am |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 |
Mine is the 10/2007 http://www.clublandrovertt.org/index.php?a...ype=avatar
This is what happens to me. Sorry about the comments are in Spanish and is very difficult to conduct and record at a time. It looks at minute 5.53. It is very mild, just as it passes the slope and the terrain is flat. If the slope is longer def takes much more in reacionar vaja speed and max 40 or 50km / h, till they recovered. On Thursday it enchufare to a friend's computer and try.
&feature=youtu.be http://www.clublandrovertt.org/index.php?a...ype=avatar |
31st Jul 2012 3:47pm |
Morea,
in my opinion the temperature gradient is too much fast..... I'm thinking about a sort of electrical signal "derivation" or something else. Should be interesting to monitoring the fact by a nanocom for recording the engine temp and other sensor outputs...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
31st Jul 2012 5:16pm |
by the way, 34 °C here in Venice area and the car still going fast.
BAS remap, Allisport uprated intercooler, hybrid turbo. Should be interesting to monitor the fuel temp also. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
31st Jul 2012 5:18pm |
On Thursday it will plug in and watch the engine to run everything. Thank you very much for your help.
Good preparation. That fuel consumption is now? Thank you. http://www.clublandrovertt.org/index.php?a...ype=avatar |
31st Jul 2012 7:35pm |
