Home > Technical > Power loss in hot weather?
Page 6 of 7 <1234567>
wslr
But if there is something in the original software causing this... Confused
Post #151370 20th Jun 2012 3:38pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
FYI
today MAF air temp on scangauge: 42°C normal traffic, dropped to 38°C on highway
no tune, mantec RAI, removed mid box exhaust, license plate on grille . RTT on top, half loaded and pushing limiter for about 40kms of hilly highway with aircon on.
CHT reached 95°C in traffic and 87 on highway
nothing, except for a consumption of 15.4 l/100km... 18 mpg
I'll throw up a (another) stone...
FUEL TEMPERATURE SENSOR
The fuel temperature sensor is located in the high pressure fuel pump.
The sensor is an NTC sensor which is connected to the ECM by two wires. The ECM fuel temperature sensor circuit consists of an internal voltage divider circuit which incorporates an NTC thermistor. As the fuel temperature rises the resistance through the sensor decreases. The output from the sensor is the change in voltage as the thermistor allows more current to pass to earth relative to the temperature of the fuel.
The ECM monitors the fuel temperature constantly. If the fuel temperature exceeds 85°Celsius (185°F), the ECM invokes an engine 'derate' strategy. This reduces the amount of fuel delivered to the injectors in order to allow the fuel to cool. When this occurs, the driver may notice a loss of performance.
Further fuel cooling is available by a bi-metallic valve diverting fuel through the fuel cooler when the fuel reaches a predetermined temperature. In hot climate markets, an electrically operated cooling fan is positioned in the air intake ducting to the fuel cooler. This is controlled by a thermostatic switch, which switches the fan on and off when the fuel reaches a predetermined temperature.
The wires to the fuel sensor are monitored by the ECM for short and open circuit. The ECM also monitors the 5V supply. If a failure occurs a fault is recorded in the ECM memory and the ECM uses a default fuel pressure value.
If the ECM registers an 'out of range' deviation between the pressure signal from the sensor and the pre-programmed 'set point' a fault is stored in the ECM memory. Depending on the extent of the deviation, the ECM will reduce the injection quantity, stop the engine immediately or prevent further engine starting.
Do you have a fuel cooler protector installed?
Do you have a full surface non perforated skidplate? (which would further reduce airflow)
Post #151372 20th Jun 2012 3:41pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
tatra805 wrote:
FYI
Out of curiosity, how do you get CHT in Celcius? The x-gauge formula I use gives the value in Fahrenheit whereas the rest of the temperatures gauges (water temp, MAF) are all Celcius (and being on the continent, I am a lot more used to Celcius than Fahrenheit)
That's a pretty bad mpg methink...
Post #151376 20th Jun 2012 4:02pm
ZeDefender
Running the remap made me go slightly faster but it made me worry more about "pushing the limits" so I went back to stock.
"Only" 24 degrees today and I was back to full(ish) speed - 145 km/h Thumbs Up
Yes - full surface skidplate (but I had the same last year without problem).
No obvious fault codes (not relating to MAF or fuel temp anyway). Tell someone you love them today because life is short.
Post #151387 20th Jun 2012 4:55pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
[quote="tatra805"]today MAF air temp on scangauge: 42°C normal traffic, dropped to 38°C on highway [/qoute]
Is this MAF temp(which will basicly mean outside temp) or MAP temp(which will be post intercooler temp)?
Where exactly is this fan located???
Post #151450 21st Jun 2012 8:05am
tatra805
Regard,
this is MAF temp, dont have a MAP temp sensor code for the scangauge only a pressure code
The text is from the workshop manual, but i could not find this fan on the illustrations.
Question
Post #151458 21st Jun 2012 9:14am
o4dn
Replying my own question, I posted how to get CHT in Celcius using a ScanGauge here:
http://www.defender2.net/forum/post151519.html#151519
Might be useful here as well...
Post #151526 23rd Jun 2012 10:40am
dgardel
Italy
Mine, during the hottest days started to have intermittence loss of power..................
every day a little worse .....
...........fuel filter clogged!!!!
New filter (the old one was full of black mud Shocked ), tank cleaned, problem gone!!!!!!!!! Mr. Green Mr. Green Mr. Green Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #156375 18th Jul 2012 9:46am
ZeDefender
Shocked That is something to check then Thumbs Up
You cleaned the tank? How much work is that? Tell someone you love them today because life is short.
Post #156424 18th Jul 2012 12:28pm
Morea
Post #158105 26th Jul 2012 5:17pm
dgardel
Italy
Yes, it is related to certain SW version, expecially on the cars upgraded P089 (for solve the cool weatber starting issue). I'm shure at 99% Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158135 26th Jul 2012 8:18pm
dgardel
Italy
When I installed the webasto, thanks God, I made
Photos taken from internt[/img] Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158139 26th Jul 2012 8:23pm
ZeDefender
Mine was doing it again today (max 130 km/h) and it's only 28 degrees outside Sad
So are there different software versions on different Defenders, selected by LR for the probable climate? Seems bizarre Rolling Eyes
My LR techie told me recently that my software version is bang up to date. Would this be the newest "cold climate" software causing my power loss?
Matt
p.s. nice system Thumbs Up Tell someone you love them today because life is short.
Post #158141 26th Jul 2012 8:34pm
Eduardo
So,
Now the things fit to me. At the beginning Bteween 2007-2010 no problem appeared, but after the software modification at the beginning of 2010 the problem pop-up
As we said here they are filling a hole making another one Evil or Very Mad Eduardo
Post #158183 26th Jul 2012 10:18pm
wslr
Was the source of this software JLR (via IDS/SDD) or from another source (e.g. Autologic)?
Post #158247 27th Jul 2012 9:13am
