![]() | Home > Maintenance & Modifications > Wiring Diagram/ Harness Diagram |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2219 ![]() ![]() |
See https://www.defender2.net/forum/post784663.html
Remove ( couple of screws) a plastic panel located in the offside rear wheel arch behind the rear lights. With a torch you will see a connector that connects the 13 pin socket to the loom, This wiring is for the lights so you can disconnect, test and clean etc. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Many thanks Ianh for your quick response, I'll have a look this weekend Defender 90XS SW
13 pin euro sockets are very good, the only downside is unlike a 7 pin they are tested as part of the MoT
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20688 ![]() ![]() |
What would happen if you had a cover on the 13 pin tow socket?
I thought they can’t remove covers? Or would that then conclude that the MOT couldn’t be properly completed? I’m just wondering, as if that’s included, and covers are also items that shouldn’t be removed then that is a clash on that subject. TheThunderRolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2715 ![]() ![]() |
Given the number of defective or inoperative vehicle/trailer lights one sees that’s a positive in my view.
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 150 ![]() ![]() ![]() |
13 pin being part of the MOT has bitten me as mine failed its MOT with the trailer connections being listed as one of the fails along with a fair list of other things. The thing is, I was halfway through fitting the socket when it went off and I left the wires from it in the back ready to splice into the light connections below the rear window....
![]() Presumibly I'll now need to pay the garage time for them to do this wiring rather than it pass its MOT and me carry on with getting it sorted. ![]() |
