![]() | Home > Faults & Fixes (L663) > Remove Wheel Arch Trim |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3034 ![]() ![]() |
These parts are difficult to remove without breakage.
Sometimes the clips break, and you can replace them. But also the plastic can break. Fortunately a new trim is not expensive and it's probably easier just to pull the old one off and fit a new complete trim. l tried to save mine but broke two of the plastic clip holders. |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 53 ![]() ![]() |
Why do you need to remove - or pry them off a bit? |
JAM911 Member Since: 13 Nov 2024 Location: Warwickshire Posts: 36 ![]() ![]() |
A small section of wrap need sticking down
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 442 ![]() ![]() |
Press the white clips in from behind with a suitable small plier. Then one by one take the wheel arch trim off.
Nothing breaks this way but it has to be clean / mud and sand free before. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thanks for the tip
l tried this on mine and still broke two clips but it must be possible.
A hairdryer might help I'm thinking?
So I have taken the fool proof , well I hope so , way of doing it.
I ordered a new set of clips, ยฃ5 for 20 from Vehicle Clips And I managed to find a brand new ( 20 miles on brand new car) set of front wheel arches in black gloss for ยฃ30 on FB Marketplace So I can remove the existing ones without worry. If you see the new ones for sale you will be able to tell I didn't break anything. Will post the results. Thanks |
USCG23 Member Since: 14 Jan 2025 Location: Arizona Posts: 34 ![]() ![]() |
You definitely need the plastic pry tool and pull straight back. I didnโt break any of my tabs or clips. However I did when I removed my extended wheel arches. I broke two clips per side. lol Ohh well. 23 LBW/Urban Defender X
20 Velar Autobiography |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
Use masking tape on your body panels so when you use your plastic pry tool (with a soft cloth behind it) you won't damage your paintwork.
I removed all of mine to replace with the LR extended wheel arches, and I damaged/broke none of them. The panbel clips do break though yet are replaceable and cost pence on ebay/amazon. |
What is this plastic pry tool you speak of?
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 128 ![]() ![]() |
Normal trim removal tools made from plastic, like these: https://www.amazon.com/dp/B0CF8WNBCJ/ref=t...8&th=1 ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar)
๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1236 ![]() ![]() ![]() |
Itโs just not worth the hassleโฆthe clips are so cheap
The design is sacrificial Just pull em off with your handsโฆno prying, no hairdryersโฆno damage. For sure the little white monsters breakโฆput new ones in! Thatโs exactly what a JLR technician would do. ![]() Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadsterโฆโฆ..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
