![]() | Home > Faults & Fixes (L663) > Remove Wheel Arch Trim |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2973 ![]() ![]() |
These parts are difficult to remove without breakage.
Sometimes the clips break, and you can replace them. But also the plastic can break. Fortunately a new trim is not expensive and it's probably easier just to pull the old one off and fit a new complete trim. l tried to save mine but broke two of the plastic clip holders. |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 51 ![]() ![]() |
Why do you need to remove - or pry them off a bit? |
JAM911 Member Since: 13 Nov 2024 Location: Warwickshire Posts: 34 ![]() ![]() |
A small section of wrap need sticking down
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
Press the white clips in from behind with a suitable small plier. Then one by one take the wheel arch trim off.
Nothing breaks this way but it has to be clean / mud and sand free before. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thanks for the tip
l tried this on mine and still broke two clips but it must be possible.
A hairdryer might help I'm thinking?
So I have taken the fool proof , well I hope so , way of doing it.
I ordered a new set of clips, £5 for 20 from Vehicle Clips And I managed to find a brand new ( 20 miles on brand new car) set of front wheel arches in black gloss for £30 on FB Marketplace So I can remove the existing ones without worry. If you see the new ones for sale you will be able to tell I didn't break anything. Will post the results. Thanks |
