Home > Faults & Fixes (L663) > Remove Wheel Arch Trim
JAM911
Hi Everyone
I need to remove my front wheel arch trims.
I watch the Powerful UK video on how to do it but they just pulled them off and broke them.
Anyone done this please and have any advice please?
I would get away with just prying them off the wheel arch a bit with out removing the completely.
Thank you
And if I need to get new clips does anyone have a source / part numbers please?
Post #1057997 20th Jan 2025 4:56pm
lightning
These parts are difficult to remove without breakage.
Sometimes the clips break, and you can replace them. But also the plastic can break.
Fortunately a new trim is not expensive and it's probably easier just to pull the old one off and fit a new complete trim.
l tried to save mine but broke two of the plastic clip holders.
Post #1058010 20th Jan 2025 7:03pm
F-Typical
Re: Remove Wheel Arch Trim
JAM911 wrote:
Hi Everyone
Thank you
Why do you need to remove - or pry them off a bit?
Post #1058039 20th Jan 2025 8:45pm
JAM911
A small section of wrap need sticking down
Post #1058041 20th Jan 2025 8:49pm
Defendit..
Netherlands
Press the white clips in from behind with a suitable small plier. Then one by one take the wheel arch trim off.
Nothing breaks this way but it has to be clean / mud and sand free before. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1058128 21st Jan 2025 2:18pm
JAM911
Thanks for the tip
Post #1058131 21st Jan 2025 2:23pm
lightning
l tried this on mine and still broke two clips but it must be possible.
Post #1058145 21st Jan 2025 6:42pm
F-Typical
A hairdryer might help I'm thinking?
Post #1058154 21st Jan 2025 7:21pm
JAM911
So I have taken the fool proof , well I hope so , way of doing it.
I ordered a new set of clips, ยฃ5 for 20 from Vehicle Clips
And I managed to find a brand new ( 20 miles on brand new car) set of front wheel arches in black gloss for ยฃ30 on FB Marketplace
So I can remove the existing ones without worry.
If you see the new ones for sale you will be able to tell I didn't break anything.
Will post the results.
Thanks
Post #1058169 21st Jan 2025 9:24pm
USCG23
United States
You definitely need the plastic pry tool and pull straight back. I didnโ€™t break any of my tabs or clips. However I did when I removed my extended wheel arches. I broke two clips per side. lol Ohh well. 23 LBW/Urban Defender X
20 Velar Autobiography
Post #1062789 13th Mar 2025 11:34am
BadgerWaz
Use masking tape on your body panels so when you use your plastic pry tool (with a soft cloth behind it) you won't damage your paintwork.
I removed all of mine to replace with the LR extended wheel arches, and I damaged/broke none of them. The panbel clips do break though yet are replaceable and cost pence on ebay/amazon.
Post #1062793 13th Mar 2025 12:04pm
lightning
What is this plastic pry tool you speak of?
Post #1062811 13th Mar 2025 2:23pm
CincyRovers1
United States
Normal trim removal tools made from plastic, like these: https://www.amazon.com/dp/B0CF8WNBCJ/ref=t...8&th=1 ๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐ƒ๐ž๐Ÿ๐ž๐ง๐๐ž๐ซ ๐Ÿ๐Ÿ๐ŸŽ ๐’ ๐๐Ÿ‘๐ŸŽ๐ŸŽ (Pangea Green over Acorn/Lunar)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ‘ ๐๐จ๐ซ๐ฌ๐œ๐ก๐ž ๐Œ๐š๐œ๐š๐ง ๐’ (Dolomite Silver over Black/Bordeaux Red)
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ• ๐ƒ๐ข๐ฌ๐œ๐จ๐ฏ๐ž๐ซ๐ฒ ๐‡๐’๐„ ๐‹๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐’๐ข๐Ÿ” (Aintree Green over Vintage Tan/Ebony) - Gone
๐Ÿ๐ŸŽ๐Ÿ๐Ÿ ๐‹๐‘๐Ÿ’ ๐‡๐’๐„ ๐Ÿ“.๐ŸŽ (Ipanema Sand over Almond/Arabica) - Gone
Post #1062815 13th Mar 2025 4:13pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Itโ€™s just not worth the hassleโ€ฆthe clips are so cheap
The design is sacrificial
Just pull em off with your handsโ€ฆno prying, no hairdryersโ€ฆno damage.
For sure the little white monsters breakโ€ฆput new ones in!
Thatโ€™s exactly what a JLR technician would do.
Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadsterโ€ฆโ€ฆ..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #1062845 13th Mar 2025 10:37pm
