Home > General & Technical (L663) > L663 D300 Auxiliary drive belt squeal.
Gareth
I’ve had this before at about 17k miles,and warranty fixed it. However at 33k it’s started squealing again.
When cold the belt is making a regular chirp, it goes silent once warmed up.
Has anyone got a picture of the installation, or a diagram of components. I think it’s one of the idler pulleys. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1057329 14th Jan 2025 8:49am
peanutbob
Hi Gareth
I guess , as you already have it fixed under warranty before, that you know that JLR issued a mod a couple of years ago, to alter the start up procedure which was using the hybrid battery which put too much pressure on the belts. They sent engineers out to alter this so that the affected defenders started up via the starter motor rather than the hybrid battery. They did this with my previous D300.
Post #1057482 15th Jan 2025 7:22pm
lightning
That's interesting.
How do you know which starting method a Defender is using. ls there any way to tell?
Post #1057490 15th Jan 2025 8:24pm
peanutbob
If it’s starts in hybrid mode it’s a muffled sound, whereas if it’s an earlier d300 and the mod was done you will hear the starter engage and then the diesel engine sound.
My first D300 was August 21 and the mod done circa 1 year later. I now have a Jan 23 d300 which starts a bit more hybrid like…but I’m not 100pc sure as it’s presently marooned in Group 1 Chester with suspension knocking and am presently running around in an Ewok hybrid which definitely starts in hybrid mode and reserves 3 - 5pc of electric to do so.
Post #1057496 15th Jan 2025 9:28pm
Gareth
Yes I do remember this. It involved a software update as well as new belt and gubbins.
I’m hoping it’s just the idler this time. There is an awful lot of vibration of the belt driven components when it’s running. I’m not actually sure which bit is the tensioner. As you look down the front of the engine under the coolant hose, on the right hand side there is what looks like an alternator. The pulley on that seems to be mounted to a bracket that vibrates a lot when the engine is running.
Access and visibility is poor, so was hoping to get a diagram of parts. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #1057497 15th Jan 2025 9:32pm
lightning
My D250 was delivered in November 2022 so hopefully the modification was done. l've never had any issues with vibration or belts squeaking.
Post #1057520 16th Jan 2025 10:08am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Had mine done twice now Rolling Eyes Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1057543 16th Jan 2025 2:33pm
Moo
Ukraine
Two years and 36,000 miles and not a steak. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1057618 17th Jan 2025 12:28am
